Old 12-05-2015, 11:56 PM   #1
steveperry
Swapping a 69 Chevy body onto a 97 Cummings chassis
So I've had a 69 k20 for about ten years and finally got the pieces together to do a Cummins swap... I've scowered the site for some having done this but I'm just seeing people putting the cummins in the Chevy chassis. Has anyone done what I'm talking about? The problem I'm seeing right off hand is the intercooler is going to be too far forward for the fender to fit right. Any help? Here's the trucks I've got to work with
steveperry is offline   Reply With Quote
Old 12-06-2015, 12:04 AM   #2
steveperry
Re: Swapping a 69 Chevy body onto a 97 Cummings chassis
Don't know how to upload more than one photo, it keeps deleting the second one so here it is
Old 12-06-2015, 12:46 AM   #3
usetheBFH
usetheBFH's Avatar
It's a tough fit. I did the 12-Valve into a C10 option. You could, being that the Dodge is a '97, get the Non-Intercooler Piping from a '93-Down 6BT and not run an intercooler. That'll let you gain ~3-4 Inches. Also trash the Mechanical fan for a thin Electric one. Tha's good for 2-Inches.
1970 C/10 | Short Bed | 2wd | 12-Valve Cummins 6BT | 47RH Auto
Instagram | usetheBFH
Coal Chute http://c10forum.com/forum/showthread.php?t=19671http://
usetheBFH is offline   Reply With Quote
Old 12-06-2015, 12:55 AM   #4
steveperry
How does that work for not having an inner Cooler? That make the diesel run hotter? I'm new to diesels.
Old 12-06-2015, 01:11 AM   #5
usetheBFH
usetheBFH's Avatar
Depends on how you build and what you're going to do with the engine. The Purpose of an intercooler is to Cool the air coming off the turbo and ultimately keep you EGT's in check. Now this is an extreme case but this guy is ~1,200 HP without an intercooler. http://www.trucktrend.com/cool-truck...s-race-engine/It very much depends on the function of the truck. If your going to do mild tuning and run it down the road you'll be fine without an intercooler. Just get a Pyro Gauge and keep it off the ~1200-1400F for any kind of duration or you'll melt stuff. I have an interccooler on mine and i can hardly get it past 1000F if i BEAT on it.
Old 12-06-2015, 01:15 AM   #6
usetheBFH
usetheBFH's Avatar
Commercial Vehicles and Construction Equipment, Like CASE Equipment, Use Non-Intercooled 12-Valve p-pump engines. That's where you get the parts from.
Old 12-06-2015, 09:43 AM   #7
Bigdav160
Bigdav160's Avatar
I don't think you can make the Dodge core support work anyway. There are examples in the diesel swap section with the dodge intercooler upside down on the GM core support
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 12-06-2015, 11:54 AM   #8
steveperry
Do you happen to have a link?
Old 12-06-2015, 12:58 PM   #9
Bigdav160
Bigdav160's Avatar
It is not on a Dodge chassis but might give you some ideas.
Cummins Suburban
edit, I'm sorry that truck is using a Bank intercooler. I'm sure I've seen others with an OE cooler.
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 12-06-2015, 01:46 PM   #10
steveperry
im gonna try and stick with the dodge chassis and put electric fans in it... Hopefully that will give me the length I need for the fenders.
Old 12-07-2015, 12:36 PM   #11
XwalkerX
i just saw this and thought of this thread.
the owner is 72 Tigger
saw it in this thread
http://67-72chevytrucks.com/vboard/s...91687&page=152
XwalkerX is offline   Reply With Quote
Old 12-07-2015, 01:59 PM   #12
68Stepper
**Cummins**
68Stepper is offline   Reply With Quote
Old 12-07-2015, 10:19 PM   #13
72 tigger
72 tigger's Avatar
I used the complete 2002 Dodge chassis (shorten the WB by 12 inches). The innercooler & radiator are tight- only about 1/2" clearance between the rad & fan. Built it in 2003 & has been my DD ever since.
72 tigger is offline   Reply With Quote
Old 12-07-2015, 11:55 PM   #14
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Z's custom rods built this 69-70 blazer on a shortened Cummins chassis. I believe you can find build pics of it on their Facebook page.
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 12-11-2015, 01:30 AM   #15
kellyed
Hey 72 tigger, you have the build for your truck on here? That's exactly what I'm looking to do!!
kellyed is offline   Reply With Quote
Old 12-11-2015, 08:28 PM   #16
72 tigger
72 tigger's Avatar
No, I didn't do a build thread- I didn't even take many pics- sorry. I can try to answer any questions
Old 12-12-2015, 11:07 PM   #17
steveperry
hey tigger, what is that radiator support out of?
Old 12-19-2015, 06:24 PM   #18
steveperry
Started pulling the Cummins apart...how many people have had the dowel pin come out? Cause I pulled the cover off and it literally fell into the bottom of the pan. It had been skipping around on top of the gear and luckily hadn't gotten sucked between the gears to destroy the engine!
Old 12-19-2015, 06:26 PM   #19
steveperry
Guess I'm going to make this a build forum as I make progress, got the dodge cab ditched, the wiring harness out and going to start cleaning up the motor and tranny to see what I'm working with.
Old 12-19-2015, 06:30 PM   #20
bigrigpardo
god you must be the luckiest guy in the world. they call it the killer dowel pin for a reason. google it good thing you found it it will kill a cummins quick.
bigrigpardo is offline   Reply With Quote
Old 12-19-2015, 06:38 PM   #21
steveperry
Yeah I know, pulled it to install the Kdp kit and there it was. You can see the scoring marks from where it was clanking around in there!
Old 12-20-2015, 02:56 PM   #22
steveperry
Can anyone tell me if I need to reinstall the dowel pin? The only thing I can find is that the pin is used for alignment when the timing case is bolted to the block...why would I need to reinstall it? I don't plan on taking the case off so I guess I don't understand the need for it. I did however make a retainer for it, and pushed the pin back in. Just curious I guess if anyone has left it out after ward.
Old 12-20-2015, 03:00 PM   #23
steveperry
Moved the truck out into the driveway to remove the cab. Pretty easy with three helpers. Rolled it back in and let the engine tear down begin!!
Old 12-20-2015, 06:56 PM   #24
garmar
garmar's Avatar
Wow! Glad to see the KDP didn't trash your motor. Interesting build.
garmar is offline   Reply With Quote
Old 12-21-2015, 12:31 AM   #25
steveperry
Not much in the way of progress tonight, have to work on the truck after the kids go to bed but I got the wiring harness stripped off the motor and the brake assembly removed.
