![]() Join Date: Jan 2012
Welding
I posted this over in the Bodywork side, but there is a lot more traffic here so I posted a link here.
http://67-72chevytrucks.com/vboard/s...d.php?t=690746
Matt Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=672655 "Father thank you for the gathering of friends, Father we give thanks for all the choices we've made because that's what makes us who we are, let us forever cherish the loved ones we've lost along the way and most of all THANK YOU FOR FAST CARS!" |
Re: Welding
Turn down the heat a little if you can and slow down the wire just a touch that should stop the popping I assume the gun is "bouncy" that indicates the wire speed is way too fast.
Re: Welding
Few things to try.
Change your wire size to .023 , it will help a lot . Now that the edges are blown away you have a few choices. 1. Cut out and add in a strip to get your edges back . 2. You can use a copper spoon / bar to Remove excess heat and helps welding up holes without blowing the hole bigger. 3.Lower your heat setting and do faster faster tacks to keep the heat away from the edges. The .030 is little big for sheet metal but can work if you take your time.
1972 Custom Deluxe 20 4x4 burb 1971 GMC SWB CST 4x4 1972 GMC k20 4x4 (X- brush truck ) 1971 Chevy CST Blazer 4x4 1971 Chevy C/10 1970 Cab Chassis C30 157" 1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica ) 1988 Chevy V30 4x4 wrecker challenger 4812 |
