Old 12-06-2015, 06:11 PM   #1
Waldoe
what is this, park switch?
This under the steering column. It looks like some sort of transformer, the wires are not connected to anything, and it appears to do nothing. Maybe on top of the steering column there is "saftey switch to only start in park" . Only thought I can come up with. I have never saw a steering column out before. Thanks
1970 GMC Sierra Grande Custom 2500
265/70/16, th400, 502ht
Waldoe is offline   Reply With Quote
Old 12-06-2015, 06:37 PM   #2
hugger6933
Re: what is this, park switch?
The NSS[= Neutral Safety Switch] is about 1 1/2 to 2 inches tall and about 3 inches long in an arching motion at the column tube conforming to the tube just a few inches above the cowl. It has dual functions, one is a switch to allow the truck to start only in park or neutral, and also light the reverse lamp when that gear is chosen. It has a tang that rides in a groove in the shifter tube that corresponds with the gears selected.
hugger6933 is offline   Reply With Quote
Old 12-06-2015, 06:38 PM   #3
hugger6933
It is also held on by two tiny little screws on opposite ends of the switch.
Old 12-06-2015, 07:20 PM   #4
Andy4639
Old member
Andy4639's Avatar
Question Re: what is this, park switch?
That picture isn't the best. I can't make out anything. It looks like someone added something though.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 12-06-2015, 07:45 PM   #5
Waldoe
This is a better pic from under the dash. You can see the speedo cable beside it. It is mounted to the bracket for the steering column. Hugger may have answered what it is, but only a switch would be needed for that, not a transformer if that is what this is. The oic shows the disconnected wires that went to something.
Old 12-06-2015, 07:58 PM   #6
Andy4639
Old member
Andy4639's Avatar
Talking Re: what is this, park switch?
That transformer are coil is mind blowing! Ha! No telling what they had hooked up.
I've seen some bizarre stuff on here that people have posted that the person before them had hooked up but this one is way out there.
Old 12-06-2015, 08:08 PM   #7
hugger6933
That is def not needed to work the NSS
Old 12-06-2015, 08:42 PM   #8
EARNHARDT#3
EARNHARDT#3's Avatar
Follow the wiring.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline   Reply With Quote
Old 12-06-2015, 08:51 PM   #9
Waldoe
It is real easy to follow the wiring. It starts where I marked the line at, and it ends where I marked the other line at. Being as no one knows what it is for, it must not be a stock item, which is all I wanted to know. I can guess as well as anyone. A transformer needs two more wires to do anything, which this does not have. [ input and output ] Thanks
Old 12-06-2015, 09:15 PM   #10
EARNHARDT#3
Take it out and throw is in the garbage.
Old 12-06-2015, 09:18 PM   #11
Waldoe
I think i will leave it there for a while.
Old 12-06-2015, 09:44 PM   #12
ray_mcavoy
Yeah, that's definitely not a stock item.
With only 2 wires, I'd say it's a choke ... the electrical kind ... not carburetor ---> https://en.wikipedia.org/wiki/Choke_%28electronics%29
It was most likely added to combat radio interference from the alternator and/or ignition system. In which case it would have been connected inline with the radio's power supply wire.
ray_mcavoy is offline   Reply With Quote
Old 12-06-2015, 09:45 PM   #13
Gromit
Could it be part of a system for an electric trailer brake? (or other system on something being towed like an RV?)
Maybe if you could read the number on the transformer we could look it up and see what voltage it is stepping up or down to - probably all still Direct Current I would hope - in other words not DC to AC..
Gromit is offline   Reply With Quote
Old 12-06-2015, 09:52 PM   #14
EARNHARDT#3
Yeah who knows maybe it'll start working.
Old 12-06-2015, 09:52 PM   #15
Waldoe
choke ,That is an interesting thought. I never new of that. It definitely only has 2 wires, provided nothing comes out the top of it and into the column. It also has a break controller on the truck, and it was built for towing. Has a goose neck ball in the bed. My curiosity is up now. I will look at daylight tommorrow for more info. I think the truck also hauled a camper at times. Thanks for the info.
Old 12-06-2015, 10:08 PM   #16
Hutch
Hutch's Avatar
Just a guess
Step down transformer
To supply the correct voltage for a particular device.
Some thing that is not the typical 12 volts
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 12-06-2015, 10:19 PM   #17
Andy4639
Old member
Andy4639's Avatar
Who cares what it was for! It's not factory are stock are anything to do with the truck in original form what so ever! Trash it. Are leave it alone. It's not hurting anything now!
Old 12-07-2015, 09:37 AM   #18
EARNHARDT#3
The OP.
Old 12-07-2015, 11:39 AM   #19
fishyalien
Looks like an old Radio Shack power transformer for a radio to remove line interference from the alternator and charging system.
fishyalien is offline   Reply With Quote
Old 12-07-2015, 12:41 PM   #20
ERASER5
ERASER5's Avatar
DO NOT REMOVE IT! Your truck is special. We can all see that it is a Transformer!
But if it doesn't run right and costs you a lot of money, maybe it is really a Decepticon.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 12-07-2015, 12:55 PM   #21
First c10
First c10's Avatar
Its a Fire Starter???
I would definitely disconnect it until I found out what it was and if it is needed.....
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 12-07-2015, 04:46 PM   #22
Andy4639
Old member
Andy4639's Avatar
Originally Posted by EARNHARDT#3 View Post
The OP.
You sure about that! We've already figured out it's not needed for the truck to run and that it's not a factory option so what good is it? It's not hooked up to anything either by the way.
EARNHARDT#3
Follow the wiring.
The OP stated that in his first post that it wasn't hooked up.
Old 12-07-2015, 05:00 PM   #23
EARNHARDT#3
Originally Posted by andy4639 View Post
you sure about that! We've already figured out it's not needed for the truck to run and that it's not a factory option so what good is it? It's not hooked up to anything either by the way.
the op stated that in his first post that it wasn't hooked up.
Old 12-07-2015, 05:55 PM   #24
Grumpy old man
Grumpy old man's Avatar
Do not remove ! It's an original FLUX CAPACITOR PROTOTYPE IF YOU REMOVE IT YOU WILL BE TRANSPORTED BACK TO 1969 ....Groovy baby ! Now I have to go crawl under all my trucks looking for another one ! I'm ready to go back to 69 !!!!!!!!
Grumpy old man is offline   Reply With Quote
