Old 12-06-2015, 09:32 PM   #1
sherm6413
Help! What AN fitting connects to fuel filter?
Stupid question but I can on find which fittings I need for my AN6 braided hose to connect in and out of my efi fuel filter.... I have pictures of fuel filter and hose
sherm6413 is offline   Reply With Quote
Old 12-06-2015, 10:00 PM   #2
clemsonteg
Re: Help! What AN fitting connects to fuel filter?
Hard to tell because the picture is blurry on my phone, but it looks like that fuel filter uses barb fittings. To use fittings you could get an AN to barb fitting and then use a small piece of fuel injection hose and clamps.
http://m.summitracing.com/search/par...-barb-fittings
clemsonteg is offline   Reply With Quote
Old 12-06-2015, 10:05 PM   #3
sherm6413
I thought about that but I was under the impression that barbed fittings and hide clamps wasn't sufficient for efi on Ls swaps because of the pressure...? If I'm Wrong that would be easy enough
Old 12-06-2015, 11:38 PM   #4
clemsonteg
I don't think it's the most ideal situation, but it's the only way you are going to use that filter. They make FI rated hose clamps and hose, so it is possible. Have you considered purchasing a fuel filter for the donor vehicle of your motor and adapting it? For example, my motor came from a 2003 Silverado and parts stores carry a fuel filter with female threaded fittings on either side which I am sure could be adapted to an fittings.
Old 12-06-2015, 11:53 PM   #5
sherm6413
Thanks for your help, this is my first swap and I didn't even. Think of that, I will order one like that and then use the quick connect an fittings! Sometimes I need another point of view, thanks again Clemson
Old 12-07-2015, 12:47 AM   #6
clemsonteg
You can get one with qc fittings made into it. Found this from searching, Hastings Filters GF283 In-Line Fuel Filter https://www.amazon.com/dp/B000C3B9Q4..._baqzwb4GWHSZF
Old 12-07-2015, 03:18 PM   #7
JJH Jimmy
JJH Jimmy's Avatar
I got a filter with NPT ends and then AN to NPT adapters for the fuel line. Here is a link to the filter.
http://www.spiderautomotive.com/70160.html
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 12-13-2015, 10:21 PM   #8
mild68
mild68's Avatar
mild68 is offline   Reply With Quote
