12-06-2015, 10:43 PM | #1 |
87 TBI 350 won't start
One week ago I changed the timing chain & oil pan gasket as well as install a sleeve on the harmonic balancer. Cranked and ran fine, drove it about 10 miles. This past week I went back to an electric oil pressure gage ,so I had the cluster out to install the gage and paint the needles. Hooked the battery back up, cranked it and it started but only ran for a few seconds. I should add that the oil pressure gage went to 60 psi while it was running. Turned it over again and nothing. I can smell fuel so I don't think it is the pump. Checked the wiring on distributor found a the pink ign. wire loose in a crimped connector and fixed that, Next I pulled the wire on the coil and it was crusty to say the least so put a new coil on and still no luck. Ran out of daylight so hear I am. Any suggestions in which direction would be great. I will check dist. cap and components in the morning, but anything else I should look at ? P.S.The vss is hooked up but i don't think that would be it.
84 step side 87 swb |
12-06-2015, 11:49 PM | #2 |
Re: 87 TBI 350 won't start
Try the module in the dist. I had a crusty coil wire in my 88 tbi and changed it thinking it was the problem. I think a bad coil wire can wipe out the module.
12-06-2015, 11:58 PM | #3 |
Thanks Ray, i'll try it.
12-07-2015, 10:48 AM | #4 |
Ignition control module. They are horrible on these TBI trucks. I just finished running this circus on my 87. Had to replace the coil as well. Make sure your grounds are all making good contact and that you have solid grounds to the firewall and engine block. I had some grounding issues as well that were making the problem worse. Would bet money on the ignition control module though. Probably a good idea to keep a spare in the truck as well.
I went through a couple of house brand name modules until finally pulling the trigger on a delco module. Been good since. |
12-07-2015, 12:11 PM | #5 |
It was the ICM, changed it, the cap & rotor, and coil. Fired right up. They didn't have an AC Delco but I will get one for sure and keep it in the truck. Thanks for every ones help. Now for a quick wash and drive it to work this evening. Oh my speedo cable is making noise so I will have to reconnect it.
