Old 12-06-2015, 11:24 PM   #1
joeydurango
joeydurango's Avatar
Thinking about another truck and need some opinions...
...and we all know what they say about opinions - everybody's got one.
I had to sell my truck some months ago. Was bummed but needed the cash. Things are better now and I'm thinking about getting another K10, but more stock/original than the last one (which was LS-swapped and lifted). Found one and have been talking with the seller, and I have a few questions for the board. See attached photos for reference. A little info first:
-'72 K10 Cheyenne Super longbed, 350/350.
-Sounds like it's pretty much original, with no known rebuilds of anything, no known repaint beyond touch-ups, etc.
-Everything pretty much works, no major known issues.
-Odometer reads 41k, although it's probably 141k.
-From the photos, I can tell it needs cab mounts.
-Needs tires, no spare, surface rust here and there, small oil leaks - little things.
-Things that make me concerned: The drip rail has been completely filled in with Bondo; The AC compressor is beginning to make noise; there's occasionally drips of coolant inside the cab; and when cold, it takes a moment to engage in reverse.
Given all that, my questions are:
-If the drip rail's been Bondo-ed for years and there's no bubbling or obvious rust, is that probably okay?
-Is it possible to buy a shorter v-belt and simply bypass the AC compressor altogether?
-That in-cab coolant leak could be anything from a loose connection to a bad heater core. Is the heater core swap as bad as I've always heard?
-I am clueless when it comes to transmissions. Is the slow-to-engage-reverse a sign of a necessary impending rebuild, or could it be a simple linkage adjustment?
And finally, most importantly: What do you figure it's realistically worth? I've got my idea, but I want to hear yours...
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER
1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD
1976 Trans Am | 400/4-spd | SOLD
1976 Trans Am | 455/4-spd | TOTALED
joeydurango is offline   Reply With Quote
Old 12-06-2015, 11:43 PM   #2
Clavo106
Re: Thinking about another truck and need some opinions...
imo I would pay 5k max.. the only thing that concerns me is the bondo on he drip rail?
Clavo106 is offline   Reply With Quote
Old 12-06-2015, 11:49 PM   #3
beerformeplz
Id say 6-7k. What did you get for your last one with the LS swap?
beerformeplz is offline   Reply With Quote
Old 12-07-2015, 01:16 AM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Are you sure the material in the drip rail is bondo or could it be sealant. Any problems inside above the windshield?
Yes you can by-pass the A/C compressor.
Coolant inside the cab would more than likely be the heater core. The A/C cores aren't too bad. You should be able to get to it from inside the cab.
Can't help on the trans.
LockDoc
Leon
Old 12-07-2015, 01:48 AM   #5
toolboxchev
Look for wear on the brake pedal. The ones with 150k you will see the edge from wear from where ones shoe would transition from the gas pedal.
Look for other signs of obvious wear and hidden areas like up under the dash.
toolboxchev is offline   Reply With Quote
Old 12-07-2015, 01:49 AM   #6
Sklptrljay
Sklptrljay's Avatar
I'm looking at these pictures on my phone, so it's not the biggest image, but it looks like I see a drip rail over the door. Like Lock doc said, it's probably just the sealant your seeing over the top of the drip rail.
Around my area that truck would fetch good money. People are asking ridiculous $$$$ for 4wd's. I'd say it's worth $8-9,000 in my area.
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list.
1972 GMC 4X4 K1500 Survivor - Sold
No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy
Sklptrljay is offline   Reply With Quote
Old 12-07-2015, 03:37 AM   #7
toolboxchev
Are you trying to sell it to us or looking for Mechanical Advice?
The heater core job is about an afternoon doing it right. Transmission issue serious detracts from my standpoint, upwards of 2 k for a high end quality rebuild with lifetime warranty. (if you can get that on a trans)
Figure the heater core at about 60 bucks and 90 an hour for labor. If you know a mechanic that could do it in an hour there is you cost.
Now the obvious look under the rig, take the wheels off inspect the front end, bearings, rear axle, brakes, all the fluids (watch for signs of flush and fills )
That trans fluid should be reddish brown at this point if its bright red I would highly suspect that flush and fill trick.
Old 12-07-2015, 06:07 AM   #8
Grumpy old man
Grumpy old man's Avatar
Looks pretty clean from the pictures
If I was buying it I'd want it for $5-6,000 private
If I was selling it I'd be at $12,000. on ebay
Grumpy old man is offline   Reply With Quote
Old 12-07-2015, 09:08 AM   #9
engineer_gregh
engineer_gregh's Avatar
I don't have a dog in this hunt but I've been watching that truck on eBay. I'll take 10 K10 Cheyenne Super's in that condition today for $5-6K, money is here send me your pictures! I don't think its worth what the owner is asking but its way north of a $10K in my area. Now my opinions on your questions.
-If the drip rail's been Bondo-ed for years and there's no bubbling or obvious rust, is that probably okay? I didn't see any Bondo in the rails but its tough to know with the pictures from eBay.
-Is it possible to buy a shorter v-belt and simply bypass the AC compressor altogether? You could just take the belt off the A/C.
-That in-cab coolant leak could be anything from a loose connection to a bad heater core. Is the heater core swap as bad as I've always heard? No more than $200-$300 by a mechanic.
-I am clueless when it comes to transmissions. Is the slow-to-engage-reverse a sign of a necessary impending rebuild, or could it be a simple linkage adjustment? When buying a used vehicle I always plan for the worse so I would say that you're looking at a rebuild, if not then it would be a pleasant surprise after purchase.
1971 Longbed BB Cheyenne Super
1972 Longbed SB Cheyenne Super
1972 Longbed Highlander Custom Deluxe
1975 K5 4x4 full convertible
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165
Greg Smyrna TN
engineer_gregh is offline   Reply With Quote
Old 12-07-2015, 10:23 AM   #10
68350
68350's Avatar
I'm going to guess and say it's sealant in the drip rail
The a/c has its own belt, so you can just take it off
Heater core is most likely the issue, can be done in a few hours with some patience
The transmission may be low on fluid, or ? Does it shift fine other than slow into reverse when cold?
I've seen this truck on eBay, I think the price is a bit out there, but definitely a 10k plus truck. It looks very nice
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 12-07-2015, 10:23 AM   #11
joeydurango
Thanks to all for the replies. Sounds like all the potential issues have answers that I already told myself, I just wanted to hear from people perhaps more experienced than I am with these trucks. Long story short: More cash always needed once the purchase is complete.
As to price: I see the seller's relisted this morning for a third run on eBay at a higher price than before, now at $30k minimum, with (not surprisingly) no bids. I knew the truck wasn't worth anywhere near the $25k asking price before. I was surprised to see some of you throwing out the $5-6k range; I figure closer to $8-10k makes sense, but that's why I asked, to get opinions. I'll talk with the seller again and see what happens...
Old 12-07-2015, 11:53 AM   #12
beerformeplz
Buy low, sell high. Thats the American way!
Old 12-07-2015, 12:26 PM   #13
67ChevyRedneck
67ChevyRedneck's Avatar
For his asking price, I would expect a truck that I could drive across the country and be able to eat off of the motor/frame.
You just can't ask 25K for a truck with leaking heater cores, non functional A/C, and questionable transmissions... I mean... Come on, man!
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 12-07-2015, 02:07 PM   #14
joeydurango
I know, I'm with you on that one. Don't worry, I'm working on that part of it... We'll see.
Old 12-07-2015, 07:53 PM   #15
engineer_gregh
Here is another one to check out.
http://www.ebay.com/itm/Chevrolet-C-...m=221960784869
Greg Smyrna TN
Old 12-07-2015, 08:35 PM   #16
joeydurango
That one is super nice and probably worth a lot closer to the asking price... but I don't have anywhere close to that asking price to spend.
Old 12-10-2015, 12:34 PM   #17
joeydurango
Well, talked to the seller for the final time today and he refuses to budge below $25k - which is about double what I think the truck is worth.
141k on a 350/350/NP205 - they'll all need a rebuild. Needs a heater core, and will need an AC compressor. Needs tires and could probably use diff rebuilds. I just do not see where the $25k figure is coming from. Like 67ChevyRedneck said, I can buy a fully-restored, go anywhere truck for $25k, if I had that kind of cash!
Oh well, I'll keep looking... if anyone sees anything up my alley, let me know...
Old 12-10-2015, 01:08 PM   #18
engineer_gregh
Sorry you didn't come to a deal on the truck. I agree, mechanically it will need attention. Its not until you've rebuilt one of these trucks that you start to realize just how expensive it can be. I think you would be hard pressed to buy a fully restored K-10 go anywhere truck for $25K, but hey if you're patient and search hard enough its possible. Check out my build thread and you will see how much I've spent on my truck, and its not fully restored.
Greg Smyrna TN
Old 12-10-2015, 01:24 PM   #19
joeydurango
Yep, I understand how expensive rebuilding can be - and unfortunately, since I had to sell mine, I understand how much money one can lose once the rebuild is done...
As for restored, go-anywhere trucks at a reasonable price, I've also been lurking on this one. But I'd rather have it a little more original. Nice truck though: https://denver.craigslist.org/cto/5311403840.html
Old 12-10-2015, 01:49 PM   #20
leddzepp
Moderator
leddzepp's Avatar
Originally Posted by 67chevyredneck View Post
for his asking price, i would expect a truck that i could drive across the country and be able to eat off of the motor/frame.
You just can't ask 25k for a truck with leaking heater cores, non functional a/c, and questionable transmissions... I mean... Come on, man!
x2
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 12-10-2015, 06:57 PM   #21
Grumpy old man
25K ...I'll build you 2 for that . Big difference between building one yourself and paying someone to build one for you .
Old 12-10-2015, 07:31 PM   #22
joeydurango
2 for $25k? Well shoot Grumpy, how about you build me one for $12,500?
Old 12-11-2015, 09:53 AM   #23
Grumpy old man
Correction : I'll build "myself" 2 maybe 3 for that kind of money ,But if I charged myself labor or had to pay someone to do any aspect of it that would be a whole different story .
Old 12-11-2015, 10:40 AM   #24
jocko
jocko's Avatar
Was watching the super the op shared. Nice truck, even with the mech issues. Fully agree it should be a fully functional resto at 25-30k. But 6k for a real Cheyenne Super K10 in a not so common color with no rust and a few mech flaws? Never. 12-15k is fair for this truck. Maybe even a little more if it's REALLY what you want, but that would just mean it's worth it to the buyer. Nice truck. Not 30k nice, but very nice. Odd - have never seen a vehicle relisted at a higher price.... Good luck with that.
Old 12-11-2015, 08:24 PM   #25
joeydurango
Hey Jocko, yeah, 6k seemed way low to me. I offered him 12k but he wouldn't even negotiate with that as a starter. Claimed nothing below 20k would satisfy. Fair enough - it's his truck... I'll keep looking.
