Old 12-07-2015, 02:17 AM   #1
easmithers
Talking gas pedal
I have a 71 chev that i am swaping motors , it has a cable throttle linkage ,
can i change it to older style lever and rod style , what year should i get,
any help ??
easmithers is offline   Reply With Quote
Old 12-07-2015, 10:06 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: gas pedal
any help ??
This is the first time I have ever heard of anyone going that direction. Usually it is going from linkage to cable and since that is do-able I guess you could go the other way. It will take some fabrication to the firewall. You would need the pedal assembly and linkage rod from a '67-'70 Chevy or GMC truck....
Do you mind if I ask what the reasoning is for the cable replacement?
LockDoc
Leon
Old 12-07-2015, 03:52 PM   #3
easmithers
Re: gas pedal
swapping motors, am missing bracket that cable goes into on carb and am swaping to edelbrock carb and cable gromet is broken,
am looking for parts, and info thanks.
Old 12-07-2015, 05:00 PM   #4
michael bustamante
michael bustamante's Avatar
Re: gas pedal
67-70 v8 rod and linkage should work but as stated you will have to slightly modify the firewall.
1967custom
michael bustamante is offline   Reply With Quote
Old 12-08-2015, 12:41 AM   #5
easmithers
Re: gas pedal
still looking , cable looks usable, but gromet on end is rotten and broken, have looked for
carb bracket some aftermarket are availible, any help would be helpfull
Old 12-08-2015, 09:37 AM   #6
Mike C
Mike C's Avatar
Re: gas pedal
Just buy a new cable. Much easier to do a motor/carb/intake etc. swap with a cable versus the mechanical linkage.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 12-08-2015, 09:45 AM   #7
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: gas pedal
X2 you can always find the carb bracket. They were used on GM cars too.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 12-08-2015, 11:09 AM   #8
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: gas pedal
I used one of these... Amazon.com: Mr. Gasket 5657 Steel Braided... Amazon.com: Mr. Gasket 5657 Steel Braided... It works great, especially with the Spectre duel throttle return springs and mount. Here's the whole shabang! Amazon.com: Spectre Performance 2435 Throttle... Amazon.com: Spectre Performance 2435 Throttle...
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 12-09-2015, 12:27 AM   #9
easmithers
Re: gas pedal
thanks for the help, I found the new cable today at CHEVY METAL in vancouver wash,
and found the original bracket for q-jet carb, and a universal one at napa
where I live, something will work with a little time invested, also found the cable in the brothers truck catalog also.
I am new to c 10 illness and working on a frame off resto with help of a freind
so I may ask for help again. THANKS
