Old 12-07-2015, 01:24 PM   #1
drewbert41
drewbert41's Avatar
rally tire question
I have 15x8 rallys.
Will these work ok? 215/60R15
drewbert41 is offline   Reply With Quote
Old 12-07-2015, 02:35 PM   #2
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: rally tire question
Your 215's are little small for 8 inch wide rims. The most I'd go is a 7 inch wide rim but for me with a 215 tire a 6.5 inch rim, in which there are lots of 6.5 inch wide rallys around, would be ideal.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 12-07-2015, 02:38 PM   #3
drewbert41
drewbert41's Avatar
What would be minimum for 15x8s 225?
Old 12-07-2015, 02:50 PM   #4
67ChevyRedneck
67ChevyRedneck's Avatar
What look are you going for?
Here's a comparison pic for my truck. Even the same brand of tire. All 8" wheels, 235/75/15
Didn't like how far the fronts stuck out with 8" wheels, so I went with 15x8 rear, 15x7 front. 235/70/15 rear, 215/75/15 fronts (again, 7" wheel this time).
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 12-07-2015, 02:54 PM   #5
67ChevyRedneck
Remember, an 8" rim is really almost 9" wide overall.
According to this calculator, 215's are really "pushing it" for 8" wheels.
https://www.tacomaworld.com/tirecalc...0r15-215-65r15
Make sure you check out a bunch of tire size combos with prices. Some sizes are considered oddball and are more expensive, and only available from a few manufacturers, whereas something like a 235/75/15 is extremely popular, cheap, and has a ton of choices.
Jesse James
Project "On a Dime"
Old 12-07-2015, 02:55 PM   #6
Already Gone
You could but that would be pushing it. 235's are great on 8 inch rims but pop real good on 7 inch rims. Like has been said, it depends what look you want..
Old 12-07-2015, 03:28 PM   #7
drewbert41
drewbert41's Avatar
Just looking for whatever is normal and will clear when I drop it 3/5 someday.
Old 12-07-2015, 09:16 PM   #8
jocko
jocko's Avatar
Normal is somewhere between 235/70/15 on the small end to 275/60/15 on the bigger end. If you want SHORT and far, go with a 50 aspect ratio - but I personally don't feel they fill up the wheelwell, unless you put 295/50s on the rear, then they look waay wide and somewhat tall enough. I also personally don't think any 50s look correct on the front - it's a roller skate look to me (sorry). If you want a good looking tire on rallies all the way around (same size), 255/70/15 a great size. I really think 225 is too small and 235 is the smallest I'd go. Always work within the mfgr recommendations on rim size, but you can usually comfortably go right up to their limits with no problems.
Old 12-07-2015, 10:04 PM   #9
EARNHARDT#3
EARNHARDT#3's Avatar
Nowadays they put a 185 on a 10" wheel and screw the camber up and think it's cool.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline   Reply With Quote
