Old 12-07-2015, 11:32 PM   #1
tim21391
tim21391's Avatar
72 c10 wire attached to cluster light
Hello all... Started cutting rust and redoing my truck back in 2008.. Lost my license in 09 thru 11 truck sat maybe a year or two and has sat for awhile til I feel the need to drive... Currently I've been driving it and noticed the gauge lights weren't working at night... Long story short I bought another cluster and took both and made one... Every gauge finally works now and so does the gauge cluster lights... Prior to me doing this tho I had a bulb socket on the back of the cluster that had a black wire attached.. That I traced it and went up into the column.. Found that the wire was broken and tore my column apart to see where the other end was and I was shocked I couldn't find anything so I stuck a regular bulb and socket in the place and everything seems to work fine... Anyone have an idea where that wire leads to?
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 12-07-2015, 11:47 PM   #2
72 K20
72 K20's Avatar
Re: 72 c10 wire attached to cluster light
Actually it was a fiber optic cable that lights up the shift indicator,, it takes light from the cluster light and lights up your shift indicator.
http://www.classicparts.com/1971-72-.../#.VmZWBM-FNLM
72 K20 is offline   Reply With Quote
Old 12-07-2015, 11:47 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
If the column is not a tilt that isn't a wire, it's a fiber optic cable and it goes to the gear indicator housing to light up the pointer....
LockDoc
Leon
Old 12-08-2015, 11:34 AM   #4
Skinny Kid
Yup, fiber optic. I fixed mine when I bought the truck, but it doesn't do much for lighting up the indicator. It lights up, just not great.
1971 Chevy Custom Camper/20, Hugger Orange with White Top
31,000 original miles (when purchased), 402, TH400, PS, PB, AC
As of May 2017 it now has a turbo LS in it! (Still looks stock though)
Skinny Kid is offline   Reply With Quote
Old 12-08-2015, 03:04 PM   #5
tim21391
tim21391's Avatar
Ok screw that. I'm not worried about that at all haha I know which gear I'm in haha
Old 12-08-2015, 03:05 PM   #6
tim21391
tim21391's Avatar
Anyone know why the high beam indicator light won't light up when hit switch? Used to work then I took two gauge clusters and made one its the same gauge.. Just thinking if I maybe forgot to hook something up?
