Old 12-08-2015, 03:54 PM   #1
Nodnarb76
Nodnarb76's Avatar
Header recommendation for LSX swap into 87 2wd 3/4 Ton Burb?
Like the title says need to know of a good set of headers that people have used with good results when dropping an LQ4 into a 73-87 2wd 3/4 Ton truck. That won't require any/much bending cutting etc...
I have heard some require a shift linkage modification, looking to avoid those.
Any suggestions?
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824
Nodnarb76 is offline   Reply With Quote
Old 12-08-2015, 05:55 PM   #2
foamypirate
foamypirate's Avatar
Re: Header recommendation for LSX swap into 87 2wd 3/4 Ton Burb?
Any suggestions?
If you aren't opposed to manifolds, Hooker makes a set of cast iron LS swap manifolds. They are pretty much unbeatable for clearance.
foamypirate is offline   Reply With Quote
Old 12-08-2015, 06:26 PM   #3
Nodnarb76
Nodnarb76's Avatar
Thank you
Are these the ones your are talking about?
http://www.dirtydingo.com/shop/produ...oducts_id=1575
Thanks again
Old 12-08-2015, 06:38 PM   #4
foamypirate
Yep, those are the ones.
Amazon has them cheaper though:
Amazon.com: Hooker 8501 Exhaust Manifold:... Amazon.com: Hooker 8501 Exhaust Manifold:...
Old 12-08-2015, 07:55 PM   #5
Nodnarb76
Nodnarb76's Avatar
Saved quite a bit!
Ordering them tomorrow.
Old 12-09-2015, 10:13 AM   #6
Nodnarb76
Nodnarb76's Avatar
Headers ordered, thank you.
Old 12-09-2015, 12:46 PM   #7
terrylgreenjr
I'm s little late but I used new body style 6.2 Camaro shorty headers from eBay and they worked perfect on my 91 Suburban and 77 Blazer
terrylgreenjr is offline   Reply With Quote
