Are there different length upper brackets? The reason I ask this is because I bought a new radiator and now that I am ready to install 4 years later the bracket is too tall. This is now the second radiator I have purchased they both appear to be shorter than the original. I got my radiator from the truck shop in Orange CA. The radiator is a 4 core.
MY 65 C20 BUILD http://67-72chevytrucks.com/vboard/s...d.php?t=483346 ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ Last edited by Budman56; 12-08-2015 at 11:17 PM. |
Never Ending Projects
Re: Radiator upper bracket question
Yes. I think the 2 and 3 row radiators use one bracket and the 4 row radiator uses a different one. I have seen two different ones. Not sure if there is a third one.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
Here are before and after photos of the bracket
MY 65 C20 BUILD http://67-72chevytrucks.com/vboard/s...d.php?t=483346 ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
After new radiator
I have one sitting on my desk - I'll be there shortly. What does yours measure from flat to top of saddle hump?
I am not sure I still have to measure and get back with you. I have had three of these and they were all the same size.
![]() Join Date: Mar 2005
I wound up going with an aftermarket radiator (aluminum, not a Champion) and I had to splice my original radiator bracket and make it taller. It looks like your Truck Shop radiator has a short tank on it, compared to the original.
As far as I know, GM made a couple of different heights on those original brackets. You might get lucky and find one that you won't need to modify.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
