Wheel Question
I recently bought an 83 K10. The previous owner has done : swapped axles from a 3/4, installed newer (02-06) wheels, a 4 inch Rough Country lift, and put on new 315-75R16 BFGs. When you make a full turn the tires rub the pitman arm and the the spring. I know the wheels are the issue. Can anyone tell me some specs for what I will need to get new wheels to correct this problem or is there something else I should be looking at other than the wheels?
Re: Wheel Question
Newer vehicles tend to allow for wheels with a deeper offset, which could be what you're running. I'm running 315-75R16 BFG TA KO2s on my '72 K2500 with a 4" lift. My wheels are 16x10 with a 5" offset, and I get no rubbing.
Try taking off your wheels and measure the offset.
72 K2500 Sierra Longbed Wideside 350/TH350/NP205 66 Plymouth Barracuda 225 Slant6 |
Re: Wheel Question
4" backspace is ideal.
Re: Wheel Question
Is there anything else I can or should do to make sure it doesnt rub in the future?
Re: Wheel Question
Run spacers or get new wheels with 4" or so b/s
2000 Chevy Tahoe Limited 3/5" drop 2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon stock SAS 6" |
#6 | |
![]() Join Date: Feb 2007
Re: Wheel Question
what is the back spacing of the
I think I've only ever had 4" back spaced wheels on my 67-72's and square body chevs.
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
Re: Wheel Question
6" wheel bout 5.5"
Re: Wheel Question
I have 4.5" backspace 9.75 wide 16.5 Centerlines on my Jimmy with swapped in 3/4 ton axles and that seems ideal running 35 12.5 16.5. But anything between 4 and 5 should be OK on a 10" rim.
Re: Wheel Question
I was looking at these.....http://www.4wheelparts.com/Wheels/Se...n=PXA1069-6882
They also make the same wheel in a 16x10. If I get these will the tire rub something else and cause more problems? |
Re: Wheel Question
Too wide or too much offset then they will rub on the rear part of fender. I'd do the 8"
Re: Wheel Question
If you like the wheels you have just do a search on those interwebs for "wheel spacer" or "wheel adapter" they cost a lot less than dropping major $$ for new wheels. If you get a 1/4" or 1/2" spacer I am sure it will cure the rubbing issue. If you don't like those wheels then knock yourself out trying to find wheels you do like.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks, a 5 speed AND a front hitch! |
Re: Wheel Question
Thanks for all the replies. I appreciate the help. The wheels I have are nothing special. Just a newer 16 aluminum wheel. It kinda looks like a snowflake? I would rather have a better wheel. The tires are brand new so I definitely want to keep those.
#13 |
Re: Wheel Question
Ok lets say I decide on spacers. Will it be enough to push the wheels out?
#14 |
Re: Wheel Question
Yes, 1" should work....
| Bookmarks |
