Old 12-08-2015, 07:37 PM   #1
tim21391
tim21391's Avatar
72 c10 high beam indicator
Ok last thing to tackle and trucks back up to par.. Didn't have gauge lights and working gauges except fuel and oil pressure until just this week they been down for a few years now... Bought a second cluster and took two and built one... Every gauge works and the dash lights I got fixed... Now my high beam indicator did work before I got the dash lights working.. After I got dash lights working again I switched from lows to highs and the lights work just the red light on the dash doesn't light up... Help to steer me in which direction I need to look at anyone? I suck at wiring but I feel accomplished so far
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 12-08-2015, 10:39 PM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: 72 c10 high beam indicator
Check the light green wire on the cluster plug for 12 volts. If you have it the connection may be bad on the cluster or the circuit board strip may be broken to the light. Assuming you know the light bulb is good. Remember to have the high beams on.
Name:  cluster connector with gauges.jpg
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 12-09-2015, 11:09 PM   #3
tim21391
tim21391's Avatar
sweet ill check that. thanks for the tip. bulb is new. if I do have power at plug im not gonna worry about it then because everything else works except that and the dome light.. new bulb in the dome light fuse is good but that will be on another day hahaha
Old 12-10-2015, 09:26 AM   #4
snipescastle2
snipescastle2's Avatar
Talking Re: 72 c10 high beam indicator
I'd say try another dimmer switch.....
Ben
snipescastle2 is offline   Reply With Quote
Old 12-10-2015, 09:18 PM   #5
tim21391
tim21391's Avatar
I doubt it's the dimmer switch if it still works by kicking lights high and low but I could be weong
