Old 12-08-2015, 09:55 PM   #1
cv65
cv65's Avatar
bellhousing question
anybody know if a bellhousing from a 65 c10 283 3sp is the same as ,a 65 6 cylinder 4 speed ? its the cast iron
cv65 is offline   Reply With Quote
Old 12-08-2015, 10:18 PM   #2
jdl71
jdl71's Avatar
Re: bellhousing question
Most likely, yes. The bolt pattern will be the same.
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 12-08-2015, 10:25 PM   #3
cv65
cv65's Avatar
I thought it might be the same. thanks
Old 12-09-2015, 12:48 AM   #4
TJ's Chevy
TJ's Chevy's Avatar
Should be. CaptainFab would know for sure.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 12-09-2015, 01:01 AM   #5
Captainfab
60-66 Nut
The V8 and I6 bellhousings are the same from '63-'67.
Old 12-09-2015, 01:06 AM   #6
cv65
cv65's Avatar
Thanks everyone
Old 12-10-2015, 12:04 AM   #7
scuderia
scuderia's Avatar
Originally Posted by Captainfab View Post
The V8 and I6 bell housings are the same from '63-'67.
Okay, but what if I have a '68 327 and will be using a sm465 that is currently bolted up to a '72 292? will the '65 283 or my current bell housing work? Thanks in advance Captain...
'66 C10 SWB
'64 C2 roadster
'38 Indian Scout Flattracker
'70 Triumph T120R
'81 Laverda Jota
scuderia is offline   Reply With Quote
Old 12-10-2015, 12:28 AM   #8
Captainfab
60-66 Nut
The SM465 has a front bearing retainer that measures 5-1/8" in diameter. You will need a bellhousing that has that size front register bore, which will be a '68 and up truck bellhousing. The '67 and earlier truck bellhousings have a front register bore that measures 4-11/16" in diameter.
Old 12-10-2015, 02:03 AM   #9
cv65
cv65's Avatar
are you shure you have a sm465 and not a sm420,just a thought, also check out how many splines on imput shaft, may need a different clutch disk.
Old 12-10-2015, 02:32 AM   #10
scuderia
scuderia's Avatar
For sure a 465. The clutch and flywheel I got from you was for which year 327? '67?
'66 C10 SWB
'64 C2 roadster
'70 Triumph T120R
'81 Laverda Jota
Old 12-10-2015, 03:16 AM   #11
scuderia
scuderia's Avatar
Okay thanks, looks like I can simply reuse my current bell housing then.
'66 C10 SWB
'64 C2 roadster
'70 Triumph T120R
'81 Laverda Jota
Old 12-10-2015, 03:23 AM   #12
padresag
they take a different bellhousing. the hole where the input bearing retainer goes is larger in the sm465 than it is in the sm420. the sm465 came in 1968 i believe. they both take the same clutchron.
if you are using the org b/housing then it is for a sm420 a sm465 will not fit in a b/housing that was foe a sm465 unless the hole was bored out to accommodate it
ron
padresag is offline   Reply With Quote
Old 12-10-2015, 09:42 AM   #13
cv65
cv65's Avatar
It was the orginal 283 bellhousing w/sm318 3speed,replaced with 1968 327.engine only was replaced ,hope that makes sense I will check 327 numbers today
good reading http://67-72chevytrucks.com/vboard/s...d.php?t=315084
