Old 12-09-2015, 06:51 PM   #1
cheap
Brake problems
So, after installing my new CPP 2.5" drop spindles, my brake line runs directly into my upper ball joint stud. I solved this problem by notching the caliper where the brake line comes in and rotating the brake line fitting. The hose previously entered downwards into the caliper but now enters from the side. After all this, my brake pedal feels weaker at first, but returns to normal under harder braking. Any suggestions on how to fix this?
cheap is offline   Reply With Quote
Old 12-09-2015, 08:28 PM   #2
foamypirate
foamypirate's Avatar
Re: Brake problems
You probably got some air into the lines. You will need to bleed the brakes to get it out.
foamypirate is offline   Reply With Quote
Old 12-09-2015, 08:43 PM   #3
chrismoore701
chrismoore701's Avatar
Re: Brake problems
My brakes are the same. I plan to rebleed them and see what that does
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 12-10-2015, 10:15 AM   #4
Shugalou
Shugalou's Avatar
Re: Brake problems
If you guys run into problems bleeding I highly recommend building a pressure bleeder.
I was reluctant thinking I could just pump it out...Not the case once I build a pressure bleeder it pushed a fair amount of trapped air out.
Found my dad's old truck
http://67-72chevytrucks.com/vboard/s...d.php?t=563321
Newspaper Article Publishing the quest find my dad's old truck
http://www.theglobeandmail.com/globe...ticle12494281/
Shugalou is offline   Reply With Quote
Old 12-10-2015, 11:10 AM   #5
chrismoore701
Re: Brake problems
Do you have any details of said contraption?
Chris
Old 12-10-2015, 02:25 PM   #6
Robert8096
Robert8096's Avatar
Re: Brake problems
http://motiveproducts.3dcartstores.com/
Robert8096 is offline   Reply With Quote
Old 12-10-2015, 04:19 PM   #7
chrismoore701
Re: Brake problems
Which one works the best? Did you have to fabricate a plate?
Chris
Old 12-10-2015, 04:53 PM   #8
Robert8096
Robert8096's Avatar
Re: Brake problems
No need to fab a plate. Mine was a 3 piece kit and I don't see it on the site anymore. This one has the plate that is included in my kit and works with most GM Master Cylinders. You can buy different adapters.
http://motiveproducts.3dcartstores.c...arge_p_48.html
Application Guide link at bottom of page.
http://www.motiveproducts.com/AppGuide.html
Old 12-10-2015, 07:42 PM   #9
69heavychevy
69heavychevy's Avatar
Re: Brake problems
gravity bleeding works great and is free if you have some spare nylon tubing
80 C10 SWB Step Side - 350 w/ vortec heads, TH350, 12-bolt 3.73
69heavychevy is offline   Reply With Quote
Old 12-10-2015, 08:34 PM   #10
cheap
Re: Brake problems
Brakes were bled thoroughly after install, with just gravity bleed. But I will try bleeding them again and see what happens
Old 12-11-2015, 11:44 AM   #11
Shugalou
Shugalou's Avatar
Re: Brake problems
You can build you own plate. I built mine from a cutting board and used the old gasket from my old MC - the guys on this forum encouraged me to build one after having lots of problems with air in the lines. I rebuild my entire system so more air traps.
If you look at my posts you'll see the Brake Help post
