![]() Join Date: Aug 2015
1969 Radiator Fan with AC
Can someone tell me how may blades and what size, 18 inch etc., the stock radiator fan is on a 1969 c/10 350 cu in motor with factory AC? Also, did the fan have a clutch?
Re: 1969 Radiator Fan with AC
Should have said how MANY blades...
20' Daredevil (Ret)
![]() Join Date: May 2003
Not a definitive answer for your 1969, but I'll get the ball rolling with info for my 1972 K20 with factory A/C. It has an 18" seven-blade thermal clutch fan. I believe all A/C trucks came with clutch fans.
I had a feeling it required more fan blades that the fan presently on the motor to pull more air. Thanks for the info.
![]() Join Date: May 2010
In a previous thread a couple years ago, the consensus was that A/C trucks used 7 blade clutch fans. However, my 69 3/4 ton with A/C has a 5 blade clutch fan. I am 100% sure it's original to the truck. I never had a cooling problem even hauling a huge camper throughout the west.
I was thinking that it would be at least 5 blades. Is your fan 18"" across? Mine is and has 4 blades on it and no clutch. My shroud looks original so I'm guessing an 18" fan is what it had stock.The previous owner put a good wrench 350 in it and probably used whatever fan he had laying around that bolted on. It's not the first issue I've come across Since I began the rebuild.
![]() Join Date: Feb 2000
My 69 with a 350 Factory a/c has a 7 blade, clutched fan.
Hmm...ok thanks!
#9 | |
20' Daredevil (Ret)
Yep, I'm on it!
