Old 12-10-2015, 10:58 AM   #1
americanmusc1e
americanmusc1e's Avatar
show me your rod throttle to DBC setups
My 70 has the original "rod" accelerator pedal that i need to operate the DBC throttle body on my 5.3.
I picked up a factory throttle cable out of a 2001 silverado thinking I could use it, but I don't see any way of making this work without converting to a 71-72 cable throttle.
Converting to DBW isn't really an option for me because I'm using Megasquirt instead of the GM PCM. My engine is also set pretty far back against the firewall.
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 12-10-2015, 12:06 PM   #2
ls1nova71
ls1nova71's Avatar
Re: show me your rod throttle to DBC setups
Is there a reason you dont want to convert it to a 71-72 pedal? That would be the easiest and cleanest route to go I would think. Then you could mod the Silverado cable to work with it.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 12-10-2015, 02:20 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
My phone screen cutoff the thread title at "Show me your rod"....Really glad I didn't get a nasty surprise.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 12-10-2015, 02:42 PM   #4
Hart_Rod
Hart_Rod's Avatar
Check this out: http://67-72chevytrucks.com/vboard/s...d.php?t=651123
Hart_Rod is offline   Reply With Quote
Old 12-10-2015, 03:21 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
I did exactly what you are wanting to do on the Panel Truck and it worked out good. You can use the pedal arm and the Silverado cable that you already have. I will post some pictures and explain what I did this evening.
LockDoc
Leon
Old 12-10-2015, 09:45 PM   #6
LockDoc
LockDoc's Avatar
Here is how I made my throttle cable. I used the stock LS cable by modifying it as follows: (1) I cut the swedged on end off of the firewall end of the cable. (2) I removed the cable from the housing. (3) I pulled the round plasitc end off of the housing by twisting and pulling like you were unscrewing it off of the housing. (4) I cut the housing to the correct length with an air cutoff tool and cleaned up the cut end with a small file and wire wheel to remove any burrs. (5) I re-installed the round plastic end. (6) I re-inserted the cable. Cable done! I didn’t want to cut the cable off until I made sure everything was correct. For the rear bracket I drilled a hole and cut a slot for the cable to fit into and drilled two holes in the bracket and the back mounting plate for the fuel rail and bolted it up. I still have to finish trimming the bracket. I had the carburetor stud on hand that fastens to the accelerator pedal arm but they can be purchased on e-Bay and probably other places. Here is a Lokar one that looks pretty nice but it may be too long.
http://www.ebay.com/itm/Lokar-S-1034...-/221654762770
Another type cable stud:
Amazon.com: JEGS Performance Products 157210... Amazon.com: JEGS Performance Products 157210...
Here is the type cable stop I used on the cable:
http://www.ebay.com/itm/Choke-Cable-...tWCApT&vxp=mtr
Here is a nicer looking one:
http://www.buggiesunlimited.com/prod...FYMDaQod7NkLfw
Maybe this will give you guys some ideas anyway….
LockDoc
Leon
Old 12-11-2015, 05:58 PM   #7
americanmusc1e
It's not out entirely. I was hoping to do it cheaper and with parts on hand
LOL! and you clicked on it anyway
Originally Posted by Hart_Rod View Post
All i see is DBW stuff in that thread. I don't think my MS2 supports DBW
-- Josh
Old 12-11-2015, 06:08 PM   #8
americanmusc1e
Amazon.com: JEGS Performance Products 157210 Throttle Linkage Cable Adapter Stud Kit: Automotive
LockDoc
LockDock that is brilliant! going to try to see if I have enough room between the firewall and engine to do that. if not, I guess I'll convert to the cable throttle.
-- Josh
Old 12-11-2015, 08:02 PM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Hey it sure beats what the "show what ya got" thread could potentially contain....
