Old 12-10-2015, 01:46 PM   #1
NotaBronco
NotaBronco's Avatar
What internally turns off the hazard switch?
I just replaced my turn signal switch and everything works perfectly. But when I function my hazard knob and turn the flashers on, I am not able to turn them off by just pulling the switch back out. I took the steering wheel back off and see there is a little tab inside the switch that must be pushed towards the out side of the column to turn the switch back off. My question is once I put the wheel back on, how is this tab supposed to be functioned to be turned back off?
Here is a picture of the said tab (flat, black tab on the bottom) that has to be pressed to turn the flashers back off.
NotaBronco is offline   Reply With Quote
Old 12-10-2015, 01:58 PM   #2
Kell
Kell's Avatar
Re: What internally turns off the hazard switch?
1. Did you buy a brand new switch?
2. Is this a picture of the old switch that you took apart?
I have to figure what is going on here so I can understand your question. It is a pain to put these back together so hopefully you are just showing the old switch as an example?
1970 C10 Longbed, 250 Inline 6, 3 OTT
Kell is offline   Reply With Quote
Old 12-10-2015, 02:17 PM   #3
NotaBronco
NotaBronco's Avatar
Yes sir this is the old switch. Here is the new installed.
Tab pushed in.
Old 12-10-2015, 02:18 PM   #4
NotaBronco
NotaBronco's Avatar
Tab pushed out.
Old 12-10-2015, 02:40 PM   #5
ptc
ptc's Avatar
The hazard sw works by pushing in the center button to engage the switch (ON) and the outer collar is used to disengage the switch (OFF) correct?
Does your steering wheel have to be in a certain position to allow that? It looks like there is a flat portion there that only allows it to engage at one point.
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 12-10-2015, 02:46 PM   #6
Jrainman
Jrainman's Avatar
if your truck is a 1967 year model the hazard switch is turned off by activating your blinker ,this is a 1 year feature only that GM changed in 1968
Jrainman is offline   Reply With Quote
Old 12-10-2015, 02:50 PM   #7
Kell
Kell's Avatar
I was thinking that was one piece, if you assume for a minute that your new piece is not broken then it sounds like you have something that fell behind it while you where tightening it down and it is in a bind.
Can you unscrew the 3 screws holding it and let it loose and then see if it will allow you to pull it back out the way you normally would?
Old 12-10-2015, 03:18 PM   #8
NotaBronco
NotaBronco's Avatar
Here is a short video of what I'm describing. This is from a totally separate column but the same part, so I don't think i installed it incorrectly.
Click link for video
https://vid.me/Gz1K
Old 12-10-2015, 03:42 PM   #9
Kell
Kell's Avatar
Did you try the turn signal to turn it off like Jrainman suggested? Your hazard switch does not look like the standard replacement type switch that I got so maybe you do have the 67 only switch?
AC Delco replacement that is supposed to fit 67-72 (this is what I have and looks a little different than yours)
Old 12-10-2015, 04:18 PM   #10
NotaBronco
NotaBronco's Avatar
I'm pretty sure it's the correct part. I crossed referenced the a/c delco switch with the Borg Warner part and had Orielly's Auto check to make sure it was correct as well. Turn signals do nothing to cancel the hazards as well as turning the steering wheel and pushing pressing pulling on the hazard knob. I figured the cam inside the column that also cancels the turn signals would do the same for the hazards but it doesn't. I've played with the new switch and the old and they both operate the same way.
Anothe clip of the switch installed.
https://vid.me/LYfR
Old 12-10-2015, 05:24 PM   #11
GTSideSwipe
I had that exact same issue when I replaced the turn signal switch in my 69 C20. All I did was install it and put a little force by pulling it out to turn it off. Now I can turn them off like normally.
GTSideSwipe is offline   Reply With Quote
Old 12-10-2015, 10:32 PM   #12
NotaBronco
NotaBronco's Avatar
Did you pul out on the switch assembly or the hazard knob?
Old 12-10-2015, 10:58 PM   #13
GTSideSwipe
Nope, I just put it all together and then after turning the flashers on I tried pulling the knob back out and after pulling with enough force it finally gave in. I'm pretty sure the part of the clip that locks it in is just a little too high because I got the same replacement switch so it just takes some force on the first unlock to make it able to be turned on and off with ease.
Old 12-11-2015, 10:18 AM   #14
snipescastle2
snipescastle2's Avatar
Talking Re: What internally turns off the hazard switch?
my '71 has a red button that you depress to turn on the flashers, and pull to shut them off.
Ben
snipescastle2 is offline   Reply With Quote
Old 02-02-2016, 01:17 PM   #15
geunther
geunther's Avatar
Ben
My 72 Blazer had the red switch too. Does anyone know the specifics of switches (red skinny one vs black round one) as it relates to years/plants. I am sure there has to be some pattern.
The lid is stuck on my jar of anti seize
geunther is offline   Reply With Quote
Old 02-02-2016, 03:04 PM   #16
'68OrangeSunshine
'68OrangeSunshine's Avatar
The skinny Red Hazard Warning Switch was the original part. They get brittle and sometimes snap off. The Black switch with outer ring was the AC-Delco replacement. The red switch was earlier nd the black switch was later production, but I don't know the timeline for certain.
I thought the red switch was from '68, [my '67 has a chrome button like a door lock tab] and the black switch came on by '70 or '71, but I see red switch examples in later trucks, so I'm confused.
I remember replacing my red switch Turn Signal Switch assembly in 1978 when the red tab broke and there were other issues with the TSW. The Chevy dealer sold me a black tab T/S Switch as factory replacement.
Old 02-02-2016, 06:37 PM   #17
GTSideSwipe
The 67s came with either a chrome knob or the red one. 68-72 model years only had the red one which is what I have in my 69 now after finding out the original design switch is reproduced. If I'm correct hey changed it in 73 to 94 to what you get now at most if not all autoparts stores. Here's a photo of our 94 silverado and it has the black one. I personally don't like the black one. I know you can get an original design switch at classicparts.com
Old 02-03-2016, 08:25 AM   #18
Right, the replacement is the '73-up part. The only difference is the knob design. The red nob didn't normally break, the signal cam would break and the knob is part of that unit. In '73 the harness connection changed also, and that is why you need the straight to horse shoe adapter.
