12-10-2015, 08:47 PM | #1 |
Door push button
Installing my courtesy push buttons for the doors and seem to be slightly stripped. Can't tighten. Any idea how to keep these tight? Thinking a little jb weld
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart My build 2008-2016. http://m.imgur.com/a/bURrE |
12-10-2015, 10:09 PM | #2 |
Re: Door push button
Is there a fat washer on these buttons? I found some that look like they wold go on
12-10-2015, 10:21 PM | #3 |
Sure that would make them good and tight but aren't they supposed to provide an electrical ground? I'd think this might insulate the threads from the jamb.
77 Chevy K20 Longbed 86 GMC C3500 Dually 07 Silverado 2500HD All standard cabs |
12-10-2015, 10:24 PM | #4 |
Courtesy push button?
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
12-10-2015, 10:47 PM | #5 |
Yes courtesy push buttons And they are supposed to have good ground
12-10-2015, 11:11 PM | #6 |
What is that?
12-11-2015, 12:05 AM | #7 |
They are the buttons in the door jam that are depressed when you close the door and that turns off your done and courtesy lights
12-11-2015, 12:30 AM | #8 |
Oh ok. I've always referred to them as a door jam switch or door ajar switch. Thanks for the clarification though.
12-11-2015, 11:10 AM | #9 |
I got door jamb switches from an 86 square at the pick and pull. My switches would hang up and not release when the doors were opened. The later model truck switches are a lot better quality and don't hang up like the older ones. I tried aftermarket switches but they had the same problem, so don't get those.
These switches are cheap at the pick and pull so I would just install new ones. My guess is that even later model trucks, like into the 90s, have the same switches so I would look for those also. These door switches are not very sturdy, so if you try to cobble your switches up to make them work they likely will continue to give you problems. |
12-12-2015, 08:13 AM | #10 |
The truck is painted. I was thinking of just tagging the side of the hole with a spot weld. Just a little something for the switch to grab. I have a thin washer to cover the damage to the paint. Was going to clamp the welder ground on the ground strap from frame to cab. Is there a chance for electrical damage? Is this a bad idea?
12-12-2015, 11:36 AM | #11 |
