Old 12-10-2015, 09:42 PM   #1
1971redc10
Fuel tank relocation ideas
Let's see some of your fuel tank modification. I don't want mine in the cab just need some ideas on where and how to put it.
1971redc10 is offline   Reply With Quote
Old 12-10-2015, 09:46 PM   #2
EARNHARDT#3
EARNHARDT#3's Avatar
Re: Fuel tank relocation ideas
This is a neat idea. I wonder if anyone has done it? Subscribed!
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline   Reply With Quote
Old 12-10-2015, 09:50 PM   #3
kingstrider
kingstrider's Avatar
lol
1972 Cheyenne Super swb:
http://67-72chevytrucks.com/vboard/s...d.php?t=684318
kingstrider is offline   Reply With Quote
Old 12-10-2015, 10:35 PM   #4
swamp rat
swamp rat's Avatar
ROTF!!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 12-10-2015, 10:40 PM   #5
swamp rat
swamp rat's Avatar
Let me help, this subject has probably been covered more than an oil thread.
If you have not already give the search function a try, look at the blur bar, click search, drop down menu, advanced search, start typing in key words like "Gas tank relocation" "Under bed gas tank" ect
Then think about the options for the filler, "In bed filler" "Tail light filler" "Running lamp filler" "Flip door filler"
Good luck.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 12-12-2015, 01:45 PM   #6
Gimme Jimmy
You can use an early Blazer tank behind the rear axle. The holes for the mounting straps are already there. It may be necessary to cut or modify one of the bed supports, and the loatio of the fill port would have to be worked out. (the fill is oriented towards the drivers side)
Gimme Jimmy is offline   Reply With Quote
Old 12-12-2015, 02:05 PM   #7
davepl
davepl's Avatar
I posted the search link for this last night! Needs to be in the captcha for signup...
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
