![]() Join Date: Sep 2009
what kind of temp sensors do I need?
So I'm getting around to installing my wire harness tomorrow and I just picked up a Taurus fan from ecology... but I'm not too sure which temp sensors I need and where would be the best place to install them... I plan on installing 2 of them for the hi and the lo... thanks...
Re: what kind of temp sensors do I need?
The Duralast part number for the 190 temp sensor is SW505, there's 2 others AutoZone. The plug is a blade type. If you need a different temp. I have the numbers somewhere. Let me know.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member). |
That temp may be wrong. I have 215 degree written down. The others are sw500, sw555, sw204 is stock for 3rd Gen F-bodies.
AutoZone
Duralast SW555- 204° on $31.99 Duralast SW505- 213° on $8.99 Duralast SW500- 224° on $8.99 Duralast SW502- 229° on $5.99 stock.
