12-11-2015, 11:40 AM | #1 |
Need help with factory A/C lines 1967 GMC
Hey guys I'm adding a factory style A/C setup to my 67 GMC project and I am needing some assistance. My radiator support does not have holes drilled for the tubes that run from the condenser through the core or the holes for the receiver/dryer mounting brackets. Does anyone have a picture or measurements of the holes? Thanks for any help!
1949 Chevy 3100 Five Window 1964 Chevy C10 Lambrecht Auction project 1967 Chevy SWB K10 1967 GMC K15 Project Build thread- http://67-72chevytrucks.com/vboard/s...72#post6502772 1968 Chevy Anniversary K10 1991 K5 4" Lift 35's (the wife's toy) |
12-11-2015, 01:16 PM | #2 |
Re: Need help with factory A/C lines 1967 GMC
Will this help you out.
12-11-2015, 03:04 PM | #3 |
Your in luck buddy, with Benny's picture as a reference, look at that location on your own radiator support and you will find (from the engine compartment out to the front towards the back of the grill) you will find dimples stamped in for the AC lines to go through. The only problem is these were punched in from the backside of the radiator support, so you will need a drill that is small enough to fit inbetween the radiator support, battery tray, and passenger inner fender, you'll need to drill through the "bracing" of the radiator support by the battery tray and then into the face of the radiator support. Once you still a pilot hole you can go from the front of the radiator support and drill in with a hole saw, I can't remember the size for sure it was I believe 1-1/4" but I wouldn't take my word for it.
12-11-2015, 09:20 PM | #4 |
Awesome thanks guys. I got it put together tonight and it looks great!
