Old 12-11-2015, 03:35 PM   #1
blown240
blown240's Avatar
Wet Roads = Squirrely Steering
I thought I had the alignment on my truck pretty much set, at least for the next couple months until I upgrade to power steering. But this morning it rained, and on the wet roads my truck is all over the place!
What causes this? Camber?
I am supposed to drive about 80 miles tomorrow, but if it rains anymore, I'm stuck!
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE
blown240 is offline   Reply With Quote
Old 12-11-2015, 03:42 PM   #2
slepysal
slepysal's Avatar
Re: Wet Roads = Squirrely Steering
So how are your tires?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 12-11-2015, 03:51 PM   #3
blown240
blown240's Avatar
Fronts tires are good, rears are about half worn, but this issue is definitely in the front.
It almost feels like if 1 side is in a puddle, the truck darts that way... if that makes any sense.
Old 12-11-2015, 04:18 PM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
I used to drive a 53 Chevy 5 window pickup that had manual steering (I-Beam axle) when I was younger. I used to have to "read" the road surface to know how to counter steer. Rain was not always fun.
When it's your only transportation you do what you have to do.
But to answer your question - I don't know.
Old 12-11-2015, 04:18 PM   #5
blown240
blown240's Avatar
WELL CRAP!
The question about tires got me thinking.... So I went out and double checked. The passenger side is wearing odd. I jacked up the front of the truck out by the ball joints and found play in 2 ball joints and the steering box that wasn't there 2 months ago.
At this point, I guess I have to save up some money and just go thru the entire front end.
Old 12-11-2015, 05:10 PM   #6
padresag
Originally Posted by blown240 View Post
WELL CRAP!
that play wasn't in the ball joints a little over a month ago when you replaced one and checked the rest of the steering?
ron
padresag is offline   Reply With Quote
Old 12-11-2015, 05:22 PM   #7
blown240
blown240's Avatar
ron
The other 3 were totally solid when I replaced the one. They aren't real bad yet, but there is play.
Old 12-11-2015, 07:11 PM   #8
vince1
I checked the first one and it had play so I bought them all. Changed that first one I had checked last, only to find it had never been tightened. A couple of turns of the nut would have tightened it and I suspect the originals were probably of better quality than the replacements. Oh well, I won't ever have to drill out the rivets again.
vince1 is offline   Reply With Quote
Old 12-11-2015, 07:14 PM   #9
blown240
blown240's Avatar
Mine have been changed at least once before since the uppers are bolt in. Time to do it again!
Old 12-11-2015, 08:16 PM   #10
franken
I seem to recall that if the toe is out it'll have a tendency to dart one way then the other.
franken is offline   Reply With Quote
Old 12-11-2015, 09:42 PM   #11
padresag
speaking of tires, you do not have a mixture of radials and bias on there do you?
ron
Old 12-11-2015, 10:33 PM   #12
blown240
blown240's Avatar
Nope. All 4 are Goodyears.
Old 12-11-2015, 10:53 PM   #13
padresag
goodyear made both radials and bias ply tires and and if you ran both combined it wood give one a squirrely feeling. this is an old problem from the 60's when radials first starting appearing on US production vehicles. people would put on 2 new radials and have 2 bias tires and it would give them that wandering feeling going down the road.
do you know what bias ply tire is?
ron
Old 12-11-2015, 10:59 PM   #14
blown240
blown240's Avatar
Padresag - I appreciate your help! Yes, I am very familiar with bias plys. My 56 merc and 51 Chevy had them. My panel has radials.
Good looking out though!! I appreciate your time and constructive ideas!
