Old 12-11-2015, 03:47 PM   #1
718jwh
72 Door Vent window Dimple
Any one have any experience adding the dimple to the 68-71 door ? I have a line on a nice 71 door for my 72 but would like to keep the dimple.
718jwh is offline   Reply With Quote
Old 12-11-2015, 05:41 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: 72 Door Vent window Dimple
Just use a dimple installer.... j/k..
If you drill a hole a little smaller than you want to end up with then take a shallow angle center punch and gently tap it into the hole you might have good results. The ideal thing would be to hold some kind of backer behind it to keep from indenting too big of an area. A piece of wood might even work.
Just some ideas....,
LockDoc
Leon
Old 12-11-2015, 05:49 PM   #3
briank
Ive seen people cut the dimple out of a rotten 72 and then cut the non 72 and weld that piece in.
briank is offline   Reply With Quote
