Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-11-2015, 05:31 PM   #1
Ont67shortbox
the right fuel
what race gas do I use, I have a BBC with 12-1 Comp,270 dur @.050 roller cam and Dart heads, 108/110/112?
Ont67shortbox is offline   Reply With Quote
Old 12-12-2015, 01:30 AM   #2
71Dragtruck
71Dragtruck's Avatar
Re: the right fuel
Some C12 would be more than good enough, even some VP110.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 12-12-2015, 02:01 AM   #3
djracer
djracer's Avatar
Re: the right fuel
Any of those should work? Too high an octane is safe but maybe slower. If you are gonna spray it I would run c12.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 12-12-2015, 08:42 AM   #4
Marv D
Registered Truck Offender
Marv D's Avatar
Re: the right fuel
C-12 is a standard in anything less than 13:1 and 7500rpm IMO. Just be cautious of the 'advertised' octane of others. I won't say 'ONLY' but as far as I know VP is the only fuel market that advertises MOTOR OCTANE, not some blend hype wannabe advertising octane. All of the other octane numbers mean NOTHING to a race motor,,, well here,, read this VP page,,, and look at this chart my buddy Roger put together for us. Advertised octane is a meaningless number when you see the WIDE range of interpretation some of these clowns use to sell fuel to the ricer crowd that thinks putting 114 in their Honda Civic is going to make it faster!
Not only the best consistance in fuel, but the best consistency in ET for me came from slightly 'OVER-octane-ing' what the motor needed. I mean not crazy,, you don't want 118 motor octane in a 11:1 motor, but you don't want to JUST BARELY meet the needs of the motor. I run C-14 in my little shoebox smallblock at 13.2:1 and shift at 8200 when I'm pushing it. I figured the RPM put me right over the line of what C-12 would support. It runs fine and consistant on C-12, but gives me a warm and fuzzy knowing I'm not on that ragged edge.
So all that to say,, DITTO on the VP C-12
The MOTOR octane, the lead content, and the RPM range I assume to be under 7000,,, C-12 is your fuel.
Do your self a favor and buy a 55 gallon barrel. I don't know how it is up there, but here in Az I can buy C-12 for $16 a gallon at the track in my 5 gallon pail,, or $10.80 a gallon at Western Fuels bulk plant in Phx. (most places only charge a minimal fee for a barrel exchange after you buy the first). When your burning about 3/4 - 1 gallon a pass,,, the savings adds up REAL fast!!
I've ran 76, Sonoco, VP and recently tried some ERC 110,,
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 12-12-2015, 04:24 PM   #5
AZ-K2077
Re: the right fuel
I agree with the above on vp c12 or straight 110. I have a similar 468 bbc with dart pro 1 heads final compression is 11.8. I run the 110 in it. If I was going to run the motor on the edge or spray I would definitely run c12 or
You can also look into vp blue maybe be just a little cheaper than c12 and pretty much the same fuel.
AZ-K2077 is offline   Reply With Quote
Old 12-12-2015, 05:44 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: the right fuel
Assuming your interested in fuel only, not running Corn juice or fuel+meth?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
