12-11-2015, 08:47 PM | #1 |
Wiring Kc Lights and other accessories
So i am wiring up a set of kc lights and some other accessories.I don't want to wire everything into the fuse box because it seems like a fire hazard. I would like to have some sort of separate junction block for accessories that i would like to add to keep a nice clean look. My question is what should i use, and where should it be mounted? In the cab, or in the engine compartment. Any help would be greatly appreciated.
12-12-2015, 03:31 PM | #2 |
Re: Wiring Kc Lights and other accessories
I wouldn't add anything into the fuse box inside the cab either. Everything is powered through the same 10/12 awg wire going into the cab, and with it running the headlights, heater fan, and everything else it is probably overloaded.
The way I did it and the way several FJ Cruiser and Jeep guys did it was to buy an additional fuse box. Like this here: http://www.cooperindustries.com/cont..._Tns_15300.pdf. This uses weather pack style connectors, the newer style mini fuses, and you can buy them with or without the relay slots. On my truck, I set up the headlights to be relayed through the box and used the original wire as a signal wire in the fuse box.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205 1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears 1996 Chevy Suburban K1500 350/4L60E |
12-12-2015, 04:00 PM | #3 |
Ok, i was thinking using something like this http://www.summitracing.com/parts/rfw-gw16/overview/ and branching into different circuits like this.
12-12-2015, 04:59 PM | #4 | |
What's great about these panels is that the pin slots are all the same distance apart, so just by moving pins around you can use up the relay slots for fuses. http://www.ebay.com/itm/2004-Chevrol...-/131310432314 |
12-14-2015, 03:53 AM | #5 | |
That cavalier box could be done nicely if you heat shrink all the wires and put some wire loom over them.
12-14-2015, 08:36 AM | #6 |
Definitely use a fused block...........also for hi amp accessories like KCs......always use a relay rather than wiring directly thru a switch.
12-14-2015, 12:27 PM | #7 |
I like these little auxiliary fuse blocks. They are simple with 1 hot wire going in (I normally put an inline fuse or circuit breaker to it).
Got 1 on my truck now (mounted under center console area) & used them on several vehicles in the past (under hood on top of inner fender) with zero problems. The one without cover can be found at AutoZone or wherever. The one with cover comes from marine place, like Bass Pro store or Overton catalog.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" [B]'85 C10 [B] "Corpse" '01 2500 Suburban ...party wagon & tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
12-14-2015, 01:08 PM | #8 |
So, i shouldn't go the junction block route then. Not even if i circuit protect it? All i want is an area where i can splice into power, every circuit will be fused and relayed.The Kc Supplied harness is fused and has a relayed already. Seems like ill have a lot fuses.
12-14-2015, 06:29 PM | #9 |
I would mount another fuse box like one shown above as close to the battery as possible, and run all your aftermarket accessories from it. The original fuse panel is not designed to handle high current loads that are added to it. Think of it like a pony panel you would add to your house if you needed more circuits.
12-28-2015, 08:30 AM | #10 |
Ok, i got the new fuse box added. now i want to protect the fuse box itself. What size fuse-able link should i use?
12-28-2015, 10:22 AM | #11 |
How far away is the new fuse box from the battery?If it's within a foot, I would connect it directly. Any further then I would use a maxi-fuse, not a fusible link.
12-28-2015, 10:24 AM | #12 |
it is approx 3 to 4 ft.
12-28-2015, 10:25 AM | #13 |
What size fuse should i use?
02-18-2016, 09:27 AM | #14 |
So, id like to get your opinion on how i wired power to the fuse box. Instead of wiring directly to the battery,and have hot all the time. I decided to take and splice into the ignition switch so the added fuse box is only hot now when the ignition switch is on. In between the splice into the ignition switch and fuse panel i added a 30amp fuse. Please see attached picture and let me know what you guys think.
02-18-2016, 10:01 AM | #15 | |
Charlie Daniels w/ a Tq Wrench
You are now drawing all of the current from all lights, accessories, etc through your switch, not good. You will have increased resistance on all your accessories which means dimmer lights, more heat, etc, your switch will get hot and go bad prematurely, or worse. If you want the fuse panel to be powered with the ignition switch you will want to wire a relay in. So it would go like this: Wire from battery +, 30 amp fuse inline within 18" of battery, to pin 30 on relay. Wire from pin 87 to the fuse panel Pin 85 to ground. Wire from ignition switch + to pin 86. This will switch the relay and the fuse box "on" when you turn the ignition on. It takes very minimal draw to engage the relay. Also, what gauge wiring are you using? Hard to tell from the picture, but some of it looks rather small for the loads you are running.
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s |
02-18-2016, 10:35 AM | #16 |
Ok, so i can splice into the switch but should use a relay to do so? my power wire to the fuse box i believe is 8ga. i guess i am confused on where pin 30 comes from. What gauge should i be using?
02-18-2016, 11:42 AM | #17 |
Yes, use the ignition switch as a trigger for the relay. Pin 30 comes directly from the battery. If you are using 8ga that should be plenty for the feed to the panel, it just looked smaller from the picture. For 30A, 10 ga is recommended usually.
02-18-2016, 12:12 PM | #18 |
Can you verify how i marked this diagram up? I think i am on the same page as you. How would you attach to the battery?
02-18-2016, 02:09 PM | #19 | |
85 and 86 do not have to be that heavy, 18 or 20ga is plenty as neither will be seeing much of any load as it is only the switching coil. Just attach to the battery with a ring terminal.
02-18-2016, 02:13 PM | #20 |
Thanks for all your help, you've made it very clear to me!
02-20-2016, 10:40 PM | #21 |
So i made it back out into the garage tonight. Got a decent amount done. But have a few questions. Getting ready to wire back up the coil and was wondering where i should be getting b+from to the coil (red wire in picture)? Can i get it from the fuse box, and should it be a constant b+ or hot only when key is on? I guess originally how was it powered? Secondly, the green wire is for the tach, but if you notice they are two different gauges. what am i supposed to do here, doesn't seem right to take and wire the two different gauge wires together. any help would be greatly appreciated
02-21-2016, 10:28 AM | #22 |
Coil should be hot with key on only......otherwise it won't shut off with the key after you start it.
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
02-21-2016, 04:17 PM | #23 |
Common Sense....stupid question, thanks!
02-22-2016, 06:15 PM | #24 |
Can any of you help me out with the tach wire gauge issue?
02-22-2016, 09:44 PM | #25 | ||
Or if you want to make it more like the factory configuration, run a 12ga wire from your HEI connector over to the bulkhead connector on the driver side of the firewall. Install a Packard/Delphi 56-series male connector onto the end of your 12ga wire. Then locate the special cloth-covered resistance wire that used to power the old points ignition coil. With the bulkhead connector unplugged, squeeze it's terminal edge-wise and extract it from the connector (it pulls out through the wire entry side). Finally, insert your new wire/terminal in it's place and plug the connector back in. Quote:
But if you want to avoid an inline splice and have the same gauge wire for the entire length, you can extract the terminal and it's short pigtail wire from the connector. Then install a Packard/Delphi 56-series female terminal onto the end of the wire that comes from the tach and insert it directly into the connector. |
