Old 12-12-2015, 12:56 PM   #1
67GMC CST 3
67 Upper A arm pivot shaft bracket
Pulled the front end apart on my 67 last night and found the brackets that the upper A arm pivot shaft bolts to are cracked, Do you guys know where I could find new ones? I already checked LMC, good used would be fine also if anybody has some. Thanks
67GMC CST 3 is offline   Reply With Quote
Old 12-12-2015, 07:05 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: 67 Upper A arm pivot shaft bracket
Manestruckparts.com , LMC is not on the top of anyone I knows list . also check the vendor section in here .
Grumpy old man is offline   Reply With Quote
