12-12-2015, 01:03 PM | #1 |
68 K15 Motor Mounts
When I bought the truck it did not have a front crossmember in it just some welded up perches. I bought a 4x4 crossmember and small block perches from a vendor here and installed it. Figuring that it was stock and LMC sells "stock" mounts I bought a set and tried to install them. They do not fit, the motor sits to high and the bolts will not line up. Maybe I installed them wrong, if so due tell. So what motor mounts work with the stock crossmember? Tried searching with no luck. I have found mounts that look like they will work (Energy Suspension 3.1156) but i don't want to waste more money buying the and ending up in the same place. Truck has a 350 crate motor in it.
12-12-2015, 04:37 PM | #2 |
Re: 68 K15 Motor Mounts
How tall are the mounts you have pictured? They look like about 2". I would need to go and put a tape on a stock mount to get a measurement, but I think they are closer to 1 3/8" or so.
12-12-2015, 04:46 PM | #3 |
Yes they are about 2".
12-12-2015, 04:53 PM | #4 |
All about them K’s
+1 those mounts are quite a bit thicker than the ones on my k/20. You could probably get stock style mounts from any local parts store I'd think.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
