Old 12-12-2015, 03:37 PM   #1
Kaptain Kadian
Kaptain Kadian's Avatar
check out my sub box
I built it out of 3/4 mdf and recessed in the spot for the amp. It fits just right behind the seat. I have a bar that runs on the bottom of my bucket seats that gave me some clearance issues. I really don't want to be sitting in the steering wheel. I put 2 shallow mount rockford fosgate 10 inch subs in it. I also put some kick panel speaker holders in and built a holder for some 3.5 inch speakers in the dash.
Kaptain Kadian is offline   Reply With Quote
Old 12-12-2015, 09:21 PM   #2
w4625
Re: check out my sub box
Nice !
w4625 is offline   Reply With Quote
Old 12-16-2015, 09:28 AM   #3
estebansocarras
nice!!!!
estebansocarras is offline   Reply With Quote
Old 12-16-2015, 09:42 AM   #4
midniteblues
midniteblues's Avatar
Nice job. Looks like a good fit.should sound awesome.
I made a speaker just like that for the dash in my car it works pretty good.
I used to have a sub box with 2 12" behind the seat in my old standard cab s10 it was a tight fit but
It was great for lower back massages.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 12-16-2015, 12:28 PM   #5
snipescastle2
snipescastle2's Avatar
Talking Re: check out my sub box
I'm guessing you moved your tank to under the bed? I wish I would have seen yours before I started mine, that angle at the top, that clears the mounting tabs for the top of the old fuel tank, would have helped me get mine to fit better.
I had to remove and install mine several times
Until it finally cleared those tabs...p.i.t.a.....
it was.... looks good!
Ben
snipescastle2 is offline   Reply With Quote
Old 12-16-2015, 12:39 PM   #6
leftybass209
leftybass209's Avatar
It certainly looks like you have some skills with MDF! Looks great, i'll be interested to see how it looks mounted.
leftybass209 is offline   Reply With Quote
Old 12-16-2015, 03:12 PM   #7
slowcpe
slowcpe's Avatar
Looks good. I have one of those 10" Fosgate subs for my side-by-side and it sounds great.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 12-16-2015, 03:54 PM   #8
Kaptain Kadian
I did move the tank a couple of years ago. It actually fit perfectly the 1st time. I was pretty surprised. I haven't hooked it all up yet to see how it sounds. They sent me the wrong amp, so the correct one won't be here until Thursday.
Old 12-16-2015, 04:02 PM   #9
snipescastle2
Looking good so far!!!
Old 12-16-2015, 06:13 PM   #10
Derek.Matirne
Looks like crap.....
Derek.Matirne is offline   Reply With Quote
Old 12-16-2015, 07:32 PM   #11
DoobieBrother
DoobieBrother's Avatar
Way to stay classy. Didn't you're momma ever teach you to keep your mouth shut if you don't have anything nice to say.
DoobieBrother is offline   Reply With Quote
Old 12-16-2015, 07:36 PM   #12
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: check out my sub box
Your sub box look familiar! Looks great and I like the amp hole to. I should have done mine that way.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 12-17-2015, 12:03 AM   #13
Kaptain Kadian
Thanks guys. I hope to have it hooked up this weekend
Old 12-17-2015, 07:13 AM   #14
Andy4639
Old member
Andy4639's Avatar
Question Re: check out my sub box
Keep a eye on the amp after you use it to make sure it doesn't get to hot. They need good air circulation are they will go into thermal over load.
Old 12-17-2015, 10:30 AM   #15
Kaptain Kadian
Thanks for the tip, I have buckets, so that part is open with the center console down.
Old 12-21-2015, 12:10 AM   #16
Kaptain Kadian
Got everything hooked up and rocking today. It sounds great. I don't have an extra 1/8 of an inch. I think I am going to work on moving the brake pedal back next. I hate how far up it sits.
Old 12-21-2015, 09:21 AM   #17
snipescastle2
Can you post some pics of your box installed?
Thanks!
Ben
Old 12-21-2015, 01:49 PM   #18
Kaptain Kadian
Best I could do on the way to work today. I forgot to take any pictures when I had the seat out. I will take more if I take the seat out again.
Old 12-21-2015, 02:13 PM   #19
snipescastle2
That turned out very nice!
Thanks!
Ben Smity
Old 12-21-2015, 02:27 PM   #20
snipescastle2
Thanks!
Ben Smith
Old 12-21-2015, 02:30 PM   #21
Low Elco
On the brake pedal, there's supposed to be a big rubber stop on the dash side of the travel on a brace that bolts in there. We drove ours for years without the brace, much less the stop. Box looks good!
Low Elco is offline   Reply With Quote
Old 12-21-2015, 03:06 PM   #22
Andy4639
Old member
Andy4639's Avatar
Not as nice as Kaptain Kadian but it's pretty much the same thing.
I made it as a wedge shape to fit to the back panel and used the upper gas tank mounts to hold it in place. You can see the bolts up top. The shallow subs are necessary to clear the box. It does well for what I like to listen to.
Old 12-21-2015, 03:48 PM   #23
Kaptain Kadian
The only thing I might do differently if I made another one is to put a port coming up through the bottom of the box to hide a little more of the big wires. I still could do it, but not sure I want to mess with it.
Old 12-21-2015, 03:56 PM   #24
Andy4639
Old member
Andy4639's Avatar
Both amps and all the wiring are inside the console. I also put a moffet fan on the back side of it to pull the air out of it to keep the amps cool.
