Electronics Upgrades
I finally have gotten around to upgrading the electronics on the 70 C20. I put on an HEI distributor and an alternator to replace the generator. I am looking at doing the fuse box as well. I got both the alternator ad the dizzy off of an early 80s pickup. Do any of you have suggestions for a good donor vehicle for the fuse panel? The one I got the other parts from had a panel fire so it isnt usable.
Thanks in advance! Dave |
Old member
If I was going to go that route I would get a 2000 up Chevy, GMC truck fuse panel with all the relays you can get with it. It will have more than enough hookups and everything will run off a relay are least all of it you are willing to hook to them.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
