12-12-2015, 03:56 PM | #1 |
Steering wheel puller and gizmo for removing the turn signal switch?
71 Chevy C-10, no tilt.
Anyone recommend a steering wheel puller? More than that, I saw on Youtube where a guy used a tool on his 70s car, which appeared to compress something so he could pull the clips out for removing the turn signal switch. Anyone know what that is and if it's necessary? Thank you
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 12-12-2015 at 04:24 PM. |
12-12-2015, 05:00 PM | #2 |
Re: Steering wheel puller and gizmo for removing the turn signal switch?
You can buy a harmonic balancer puller at most parts stores or Chinese tool stores. They work real good on pulling steering wheels. The tool for holding the plate down while you remove the snap ring only applies to 73 up trucks & 68 up cars that have the key in the column.
12-12-2015, 06:06 PM | #3 |
Now there was a Kent -Moore tool that was needed for pulling the upper shrouds to install the turn signal switch but that may have been on tilt only columns. I used a fine pick and ran it around the groove at the bottom and did so about 20 times or so and it got out the grime then loosened it up ever so slightly then I was able to pull upwards on it with gentle pressure and pop it loose. Jim
12-12-2015, 07:09 PM | #4 |
Thank you..........
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
12-12-2015, 07:20 PM | #5 |
loosen the steering wheel nut place your knees under the wheel and left hand on top of the steering wheel with even pressure ,using a brass hammer smack the steering loosened wheel nut and the wheel will pop off in your hands . you just saved $45.00 on a wheel puller .
12-12-2015, 08:52 PM | #6 |
20' Daredevil (Ret)
I bought a steering wheel puller like this decades ago, cheap and works well:
Sorry, no help on removing the turn signal switch.
12-12-2015, 11:11 PM | #7 | |
12-13-2015, 12:04 AM | #8 |
Auto stores will loan you one for free.
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list. 1972 GMC 4X4 K1500 Survivor - Sold No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy |
12-13-2015, 12:35 AM | #9 |
BlahBlahBlah
Hey that's the same one I have, works like a champ. You see those all the time at swap meets for a few bucks.
12-13-2015, 02:35 AM | #10 | |
1. Remove the three screws. 2. Loosen center nut to the end of the thread. I Imagine the very end of the bolt should be exposed, for #4. 3. Knees behind underneath, hand on top with a little more pressure on top (another way of saying even pressure all around). 4. Strike the bolt as hard as you can with a brass hammer BANG!. Just kidding, one sure strike, not too much behind it.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 12-13-2015 at 02:53 AM. |
12-13-2015, 07:32 AM | #11 |
I've removed 100's of wheels of of 50's -60's and 70's cars and trucks like this and it's always worked for me . you back the wheel nut off far enough to protect the threads on the column shaft when you whack the the nut .you don't want any damage to those threads .
12-13-2015, 08:34 AM | #12 |
The compression tool you saw is not necessary in these trucks. It's only needed for the later models with locking steering wheels.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
06-22-2018, 01:03 AM | #13 |
I read this thread last night, to get psyched out for replacing the turn signal switch. I tried what Grumpy recommended, but didn't work. So I used the picture of the puller, and made my own, which did the trick! I also took pictures of each step for my own use, because this is the first time I've done this, to reassemble correctly. I even thought of putting lithium grease around the shift lever and collar would be a good idea, wow, that was a 100% improvement!
Great resource this forum is!
1968 Long Bed 2016 Honda Civic Coupe EX-T ticket magnet |
10-07-2021, 05:56 PM | #14 |
Active Member
Gonna try Grumpy technique.
Wish me luck. |
