Old 12-12-2015, 05:57 PM   #1
Riley012
Electric problem
I have the headlites and tail lites, signals all working. When I turn the headlights on, all the gauges and wiper motor stop working. Any help would be appreciated. Thanks 1982 k20 Chevy truck
Riley012 is offline   Reply With Quote
Old 12-14-2015, 12:41 AM   #2
Cheyenne75
Re: Electric problem
Light switch might be bad
Cheyenne75 is offline   Reply With Quote
Old 12-14-2015, 10:14 PM   #3
Riley012
It's a new switch.
Old 12-14-2015, 11:35 PM   #4
rich weyand
rich weyand's Avatar
Ground strap between the engine and the cab missing?
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 12-15-2015, 12:00 AM   #5
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
Yep, sounds like a faulty/lack of ground issue. Make sure you ground the dash to the body and the body to the engine and frame. I also ground my tail lamps to the body and run a ground wire from that bolt to the frame, using star washers.
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
Old 12-15-2015, 11:16 PM   #6
Riley012
I have the cab grounded to the engine and the box to the frame,I do not have the cab grounded to the frame, I forgot about that one, do you think that could be my problem. Thanks
Old 12-15-2015, 11:25 PM   #7
Riley012
White elephant can you tell me if the light switch has its own ground wire coming out of the plug, or is it grounded by the large nut that holds it into the dash. I painted the dash and if it is the nut then it mite not be getting a good contact. Thanks
Old 12-16-2015, 04:31 AM   #8
hatzie
Moderator
hatzie's Avatar
The large nut is the switch ground.
You are not getting a good dash ground to the ground buss bar above the e-brake pedal.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 12-16-2015, 08:45 AM   #9
enaberif
Battery to engine
Engine to body
Those are the only two I have.
enaberif is offline   Reply With Quote
Old 12-16-2015, 10:58 AM   #10
Riley012
Hatzie I have not seen a ground bus bar above the ebrake, I have not reinstalled the ebrake pedal yet. Thanks for the info on the light switch nut.
Old 12-16-2015, 11:09 AM   #11
gmachinz
The ground buss bar is actually located on the body directly behind the lower left hand AC vent about a foot inside.
gmachinz is offline   Reply With Quote
Old 12-16-2015, 12:08 PM   #12
rich weyand
Originally Posted by enaberif View Post
Battery to engine
Engine to body
Also need battery to frame. This is usually a second smaller wire on the (-) battery cable.
Rich Weyand
1978 K10 RCSB DD.
Old 12-16-2015, 06:44 PM   #13
TheWhiteElephant
God is good!
As has been said, there should be a bolt right behind the far left A/C vent. You can also drill a small hole anywhere on sheetmetal. Remember--you can never have too many grounds. If you've checked all bulbs, fuses, the easy stuff, and all appears okay, it SHOULD be a grounding issue.
Mando
Old 12-16-2015, 06:47 PM   #14
TheWhiteElephant
God is good!
Battery to engine
Engine to body
You should really have an engine to frame and body to frame as well. Rear tail lamps on '73 and above ground to bolt on bedside, but a ground from bedside to frame is what fixed my problems.
Mando
Old 12-16-2015, 08:45 PM   #15
enaberif
I was talking strictly engine bay. Even factory there wasn't a engine to frame ground.
