66 c-10 crooked crossmember behind differential
Is there some reason my stock swb has a factory riveted crossmember just behind e differential? In middle of mustang gas tank install would be nice if it were straight, and I have no issue knocking out rivets, but, on the driver side it meets plate that holds the bar running from differential to frame bracket. I guess this is called a locating or pan hard bar, don't know. But given driver side riveted to that bracket, don't believe I can just bust loose pass side and push crossmember forward 1.5", or whatever, and bolt it back down? Thanks in advance for your thoughts
Re: 66 c-10 crooked crossmember behind differential
Sorry, meant to type why is that crossmember crooked? Hard to believe just a mistake from factory?
![]() Join Date: Jan 2011
They put them all in that way. Never knew why but they are all that way.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Yes, I've often wondered the same thing. But it's true they are all that way.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
It keeps the frame from racking
60-66 Nut
![]() ![]() Join Date: Mar 2007
I believe that crossmember is angled so that it clears the panhard bar if the differential comes up that far.
That would make sense. Supports the bracket on one end and is out the way on the other. Looked straight down on em a 100 times and that never entered my mind.
Jimmy
#8 | |
1961 crewcab
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
