![]() Join Date: Oct 2015
Help With Wheel Selection...???
I have a friend with a Brand New set of American Racing 6 lug wheels. He bought them for a 50 Chevy truck. He will give me a smoking deal on them. Im just not sure how well they will work. Can anybody give me any info? I have one wheel to try but I don't have any tires so im not sure how much I can tell by just sticking a rim on the truck.
Re: Help With Wheel Selection...???
According to that sticker they are 5 on 4.75 which is a car and s10 pattern no 6 lug. Narrow like original so a 235/75/15 for stock hight.
235/60/15 front 275 / 60 / 15 rear 15/7
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 Last edited by LVPhotos; 12-13-2015 at 12:28 PM. |
Well they are 6 lug so must be the wrong boxes. Ok I guess that was no help...
![]() Join Date: Oct 2006
If it was me I would get a used tire in the size you want to run have it mounted on the front and back and take it from there. Go to your local tire shop and tell them you need one used tire just o test fit your wheels.
With out a tire you can still test fit to see if the the wheel will clear the rear fender and if it will clear the a arms up front. I had a set of 15x8 that had saved for years for my 5 lug swap. When I did the swap I test fitted the wheel only to find out the wheel would hit the rear fender lip and moved on to plan B.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
