12-13-2015, 02:05 PM | #1 |
1971 Project
I picked up a 1971 GMC Suburban last weekend in Oregon. Trailered it home against 25 mph head winds and snowy roads. Made it home in CA after 14 hours due to only being able to go 45 mph with fishtailing. Happy as can be, but have my work cut out for me. Hoping to get a little help from the members here on a few things along the way. Previous owner made a custom tank, but no sending unit. I purchased new tank with sending unit and straps, but can't find any wire to hook up to sending unit. Don't even see a cut off wire. Can anyone tell me where it comes from... along the frame, or from the corner chanel with the tailights wiring?
12-13-2015, 02:16 PM | #2 |
Re: 1971 Project
Drivers side rear.
We like pics
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
12-13-2015, 07:03 PM | #3 |
Re: 1971 Project
Thanks, I'll look, and hopefully previous owner left wire and connector intact.
Sorry for being lazy with last post and no pictures. Here's what I'm starting with. Also another question. Do I need to use the extra two ports on the new tank, there are some extra clipped hoses under there. Last edited by theclockdoctor; 12-13-2015 at 07:14 PM. Reason: fixing pictures |
12-14-2015, 01:58 PM | #4 |
Re: 1971 Project
Congrats on the find, it looks like a great rig...3/4 ton? I brought a 1971 GMC Suburban ambulance home from almost all the way from Oregon (Siskiyou County) this past summer and had a considerably easier time with transport.
I second the motion for pics, I'd love to see more photos of GMC 'burbs.
- Mike 1971 GMC 2500 Stoner Ambulance (sold) http://public.fotki.com/Classicchp/1971-gmc-ambulance/ |
12-14-2015, 03:03 PM | #5 |
Re: 1971 Project
Just 1/2 ton, but I'm not planning on any heavy towing. Just nice daily driver, camping,going to the cabin rig.
12-14-2015, 06:49 PM | #6 |
Re: 1971 Project
Looks good! Welcome to the forum.
Bob 1967 2wd Burb, 350/TH350, 3.73 posi |
12-14-2015, 07:02 PM | #7 |
Re: 1971 Project
Welcome.
Clean lookin rig. |
12-14-2015, 10:14 PM | #8 |
Re: 1971 Project
Very nice, Welcome. When I bought my suburban the previous owner had installed a brand new tank. After I got it running and diving I noticed I had a fuel leak. I found those two extra ports had a rubber cap on them and no clamps. I just ran a hose from one side to the other and clamped both ends. Will probably do a better repair in the future but cant think of a better way to cap it off.
12-14-2015, 10:41 PM | #9 |
Re: 1971 Project
Just got a factory service manual today, an found out where everything is supposed to go. Problem is I think the evap canister is gone. I think I'm going to do the crossover and clamp method also.
12-15-2015, 11:04 PM | #10 |
Re: 1971 Project
I'm in need of a factory service manual as well...mind sharing where you picked yours up from?
12-16-2015, 02:20 AM | #11 |
Re: 1971 Project
12-16-2015, 09:34 AM | #12 |
Re: 1971 Project
Fuel separator or charcoal canister? The canister is hard to see as it is in the fender behind the battery.
PDF's of the factory service manuals are floating around this site <wink>
12-16-2015, 10:20 AM | #13 |
Re: 1971 Project
Found the canister, bit it has a hole broken in the top of it.
12-16-2015, 02:44 PM | #14 |
Re: 1971 Project
My rig has the full length overhead air unit which I don't really like the way it looks. Is it worth repairing, or just getting a dash mount Vintage air unit?
12-19-2015, 01:30 AM | #15 |
Re: 1971 Project
Fitting the new gas tank up tomorrow, but was looking at the factory manual and it showed some kind of spacer between the frame rails and the flange. Anyone know how thick of a spacer that should be?
12-19-2015, 02:53 PM | #16 |
Re: 1971 Project
I just cut rubber strips from an innertube IIRC.
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
12-19-2015, 07:34 PM | #17 |
The Older Generation
Re: 1971 Project
I used strips I cut from an old truck mud flap. About 3/16 of an inch thick. LockDoc
12-20-2015, 10:21 PM | #18 |
Re: 1971 Project
Got the tank in yesterday, and with 4 quartz of tranny fluid, it drives forward and backward now. YooHoo! Went to hook up the fuel sending unit wire up today and found that previous owner had not only cut that, but also wired up some backup lights on the bumper by running a wire through the backup light lens. He removed the backup light buld sockets, and I can't seem to find a listing for them. Anyone know what part number or where I can get some?
01-13-2016, 01:13 PM | #19 |
Re: 1971 Project
Been busy the last few weeks, had the transmission and transfer case gone through and sealed up, removed the factory mid and rear seats, removed linings from floor to see floor board holes,removed overhead ac unit and headliner, including a shopvac full of mice and rat feces. Removed and replaced the raingutter seal, but still getting just a tiny bit of moister into the front side kick panels. There are holes rusted out there which also need to be taken care of. Have the new floor panels, but I want to make sure I have all the leaks solved first. Anyone have any ideas of where the last bit of water could be getting into the driver side kick panel?
01-13-2016, 04:46 PM | #20 |
Re: 1971 Project
On my '67 Panel Truck the body seams at the top and bottom corners of the windshield were rusty and it was leaking there. I had to pull the windshield out to fix it LockDoc
01-13-2016, 05:51 PM | #21 |
Re: 1971 Project
Thanks Leon. I'm afraid mine might be the same. I need to wait till better weather to take out the windshield. That means I'll have to wait to do floorpan and kick panel repair also.
01-14-2016, 01:20 AM | #22 |
Re: 1971 Project
Random but, do you have any pictures of the previous gas tank?
Mine: 72 c20 Chevy suburban, 02 5.3 w/4l60e , factory ac and 50gal tank. 70 k10 Chevy burb, 04 5.3 w/4l60e np241, with dual 30gal saddle tanks and rear 30 gal tank Dads: 67 c10 step side(project) 72 c10 GMC burb 350/400, with 67 Chevy front clip(grocery getter) Ours: 67 c30 tow truck 70 c10 long bed 383stroker w/digital gauges(work truck) |
01-14-2016, 01:46 AM | #23 |
Re: 1971 Project
I'm out of town tomorrow, but I'll post some on Friday.
01-14-2016, 09:12 AM | #24 |
Re: 1971 Project
Great looking burb.
01-16-2016, 01:07 AM | #25 |
Re: 1971 Project
Got the new custom rear bumper done today. Tim Williamson of All Pro Fab in Turlock, CA. He does all kinds of manufacturing for the food industry, and as a side business builds some of the wickedest 4x4 jeeps and machines you'll ever see. Great to have a friend who has even better fab skills and tools than I do. Also got the Rack he made me moved from the 1989 Burb to the new 71. A few new pics.
