Old 12-13-2015, 03:00 PM   #1
crf250r
crf250r's Avatar
1971 C30 front rubber brake lines
Picked up a 1971 C30 the other day and it is said to be a one owner until this year and 33k original years but no documentation on either so who knows.
But problem is it has no brakes even if it did it would be time for a re-do anyway. I've searched rockauto, ac-delco, dorman's site, etc and have not been able to come up with any leads for the front left and right rubber brake lines and don't think they are the same as a C10 as it uses a different caliper.
So does anybody know where to source these or what have yall done when replacing them?
And here are some pics:
crf250r is offline   Reply With Quote
Old 12-13-2015, 03:02 PM   #2
crf250r
crf250r's Avatar
Re: 1971 C30 front rubber brake lines
And another:
Old 12-13-2015, 05:41 PM   #3
kwmech
When I converted my 69 to disc brake, I ended up have some hoses made
Old 12-13-2015, 08:35 PM   #4
uncle
I think they are the same. Yours will have a square shoulder on caliper end but new ones don't (71 only). I'm pretty sure when I checked at parts store that 1/2 and 1 ton calipers were same. Glad you bought it. Kept me from getting something else that would sit around.
uncle is offline   Reply With Quote
Old 12-13-2015, 09:46 PM   #5
Gimme Jimmy
A shop that custom builds hydraulic hoses can make them for your application. Locally I went to Oil Filter Service Co. in Portland or with my old ones and they duplicated them.
Gimme Jimmy is offline   Reply With Quote
Old 12-14-2015, 12:57 AM   #6
BCOWANWHEELS
I just bought a set from oriellys and sadly to say there made in china and all metric...................
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 12-14-2015, 08:27 AM   #7
I looked on NAPA's site and they don't list the front hoses (lines are metal tube). The calipers and hoses are the same on C/20 & C/30. Can a newer hose work? I use mid-late '70s C/20 front hoses on 71/72 K/20s when I lift them 4" because they are longer...and they work
Old 12-14-2015, 10:18 AM   #8
crf250r
crf250r's Avatar
Uncle-
Ok that makes more sense, I saw the square shoulder and just assumed they were very different but I'm not sure if the calipers are the same because if I read it right they are held in with clips but I would imagine the inlet still is. And yea I didn't exactly need another either but the price was right and it will be a great reference for putting my 72 C10 back together.
Special k-
Good idea, I looked it up and calipers were the same till 78 and I'd rather have the hoses a little longer than come up short. So that sounds like the way to go.
Thanks to all for the help
Old 12-14-2015, 11:01 AM   #9
jbarron
Bought mine from GMCPauls.
They had a separate description for the c20.
'72 3/4 Cheyenne Super 402/TH400 Gear Vendors
'72 3/4 Cheyenne Super 350/200R4
'50 1/2 Chevy 3 Window
jbarron is offline   Reply With Quote
