Old 12-13-2015, 10:38 PM   #1
70c10guy
engine is dying.. help!
Hi all, so my cam swap was a success. After break in, she ran excellent. Day after I started it and drove it. Drove fine, later in the day I started it and it won't stay running after it fires up. Vacuum is around 13" and I also have a holley dp that I tried adjusting the idle mixture screws. I had to turn the curb idle up so it would stay running but when I reached 15" of vacuum, I couldn't get anymore so I slowly backed out the idle speed. And it just dies. This truck was just running beautifully and it still does! Just won't idle. And I have to drive with 3 feet. (t5 manual). Any help would be appreciated, thanks!
70c10guy is offline   Reply With Quote
Old 12-13-2015, 10:40 PM   #2
aruss99
Re: engine is dying.. help!
Timing??
aruss99 is offline   Reply With Quote
Old 12-13-2015, 10:47 PM   #3
toolboxchev
Get her running, check for intake manifold leaks. Guys here know 90 percent of the time its not the carb. Check all functions of the distributor, everything.
This site is the most helpful bunch I have ever run into. They are awesome!
toolboxchev is offline   Reply With Quote
Old 12-13-2015, 11:01 PM   #4
70c10guy
I just put the truck back together, timing is set to 10* btdc vac advanced disconnected and once conenected it idled fine. But now with everything untouched it won't stay running, how could this be? I literally was just driving it.
Old 12-13-2015, 11:35 PM   #5
rsgt
rsgt's Avatar
Is your vacuum advance hooked to ported or full. If it is on full try the ported and see if it will stay running.
rsgt is offline   Reply With Quote
Old 12-13-2015, 11:40 PM   #6
70c10guy
It's on manifold and it's been on manifold!
Old 12-13-2015, 11:41 PM   #7
70c10guy
That would just retard the timing which will bring the rpms down even more if I did have it running, iive tried it before and it ran like crap and ran hot as well.
Old 12-14-2015, 12:58 AM   #8
Gromit
Sounds like your vacuum advance is adding too much advance at idle - at 15 Hg it is maxing out - probably at around 26 to 28 crankshaft degrees BTDC (plus a couple since there is likely no bushing on its pin)
Crane sells a limit plate (part 99619-1) but I just make my own and pop rivet them on.
This is all if you want to use manifold instead of ported vacuum.
I just set the stop to limit vac advance to 8 degrees; which is .086 of travel from the vac advance
http://www.nastyz28.com/~copo/distributor.htm
If you get the Crane plate ($6) I'd recommend following the way the z28 guy installs his - note it is on the other side of the pin than the Crane instructions show.
Gromit is offline   Reply With Quote
Old 12-14-2015, 07:51 AM   #9
hamjet
hamjet's Avatar
If it ran and idled fine in the beginning and now it won't idle but runs fine after the RPMs are up, "I" would be looking at the carb for plugged idle circut.(DIRT).. once the RPMs are up it goes into the power valve circut and thats why it runs fine. It does'nt rule out a vacuum leak.. First I would bring the idle back up and spray around the carb base.. If it does'nt run fine with the RPMs up then forget everything I stated, then I don't know what I'm talking about...LOL
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 12-14-2015, 08:17 AM   #10
CC69Rat
CC69Rat's Avatar
What type of fuel pump are you running on it? Is it still the original gas tank? Has the tank been cleaned? How long was it run this way before you started the cam swap, carb, etc? Daily driver or was the truck sitting for a while?
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 12-14-2015, 09:11 AM   #11
70c10guy
I just rebuilt the carb on it but I will try rebuilding it again and see what the culprit is.. fuel filter is a couple weeks old, sock in the tank has been cleaned, it sure does sound like fuel issue because it runs fine when cruising highway. The truck is and was a daily driver and I put top tier fuel in her. Fuel pump is also stock replacement type
Old 12-14-2015, 09:56 AM   #12
geezer#99
geezer#99's Avatar
What rpm and how long was the cam broke in for?
Otherwise it's timing related.
What's your initial timing and have you checked it yet?
Old 12-14-2015, 11:58 AM   #13
Skinny Kid
I wouldn't immediately suspect the carb. If I have done a major repair and then something goes wrong it almost always directly related. It's very rarely coincidence that something else goes wrong. Go over everything you did carefully and eliminate all of that before you move on with the diagnosis.
1971 Chevy Custom Camper/20, Hugger Orange with White Top
31,000 original miles (when purchased), 402, TH400, PS, PB, AC
As of May 2017 it now has a turbo LS in it! (Still looks stock though)
Skinny Kid is offline   Reply With Quote
Old 12-14-2015, 01:36 PM   #14
KY_GMC
KY_GMC's Avatar
I had this same issue with a new engine and carburetor rebuild.
Turned out that the hold down clamp was not keeping the distributor in place. I would set the timing, take if for a few runs, and then I had to limp home to find out the timing moved.
Spent yesterday revising the hold down clamp to make it hold better. So far, it is holding.
1972 GMC 1500 Super Custom, 383 Stoker, TH350
Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=592157
Engine Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=592233
KY_GMC is offline   Reply With Quote
Old 12-14-2015, 05:14 PM   #15
70c10guy
Sooo... I figured it out! I checked for vac leaks and nothing. So I went straight to the carb. I took the bowl and metering block off and it was full of crud!! I can show pics but idk how to post em.. but you get the idea! Thanks all for leading me into some possible problems. Now I know what else to check in the future! She idles strong and holds timing at 12*btdc with no pinging whatsoever. Adjusted the mixture screws on the carb and holds 15 in hg at idle. Thanks guys!
Old 12-14-2015, 05:34 PM   #16
aruss99
Glad you got it fixed!
Old 12-14-2015, 05:50 PM   #17
Boog
laying low
Boog's Avatar
Glad you figured it out. You need a better filter between the pump and carb.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 12-14-2015, 06:13 PM   #18
leftybass209
leftybass209's Avatar
PO of my truck wasted a bunch of money replacing the manifold and carb because it wouldn't stay running, same issues you've described. When I dumped the tank it looked like a rusty muddy sandbox, no wonder
I LOVE forums for getting good info out quickly. Unfortunately not all info is good info! Glad you got this sorted out!
You may want to give your tank a good look-see. The filter can only do so much and carbs are finicky little creatures. Also make sure you have a good metal line running from pump to carb, and that any rubber fuel line you do have is in good condition. I pulled several black specs of rubber from the fuel pump, and out of the idle circuit of the carb. Fuel was slowly chewing up the parts store fuel line the PO used.
leftybass209 is offline   Reply With Quote
Old 12-14-2015, 06:32 PM   #19
hamjet
hamjet's Avatar
I figured it was the carb the way you were describing it, good fix..
Thanks, Joe..
Old 12-14-2015, 06:36 PM   #20
67ChevyRedneck
67ChevyRedneck's Avatar
Great you found it, but thought I would also mention, since you're using manifold vacuum, to make sure you're unhooking and plugging the port when setting initial timing.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 12-14-2015, 09:03 PM   #21
70c10guy
Yes I'm glad also, glad it wasn't major. And yes I am plugging advance to set initial! I need a good filter.. any recommendation?
Old 12-14-2015, 09:06 PM   #22
Gimme Jimmy
Check your intake Manifold gaskets. There may be a huge vacuum leak.
Gimme Jimmy is offline   Reply With Quote
Old 12-15-2015, 07:24 AM   #23
CC69Rat
CC69Rat's Avatar
I would suggest draining and pulling your gas tank out. I know it's a lot of work but there's obviously a bunch of crud in the tank. It's just a matter of time before this happens again.
If you pull the tank wash the inside out really good. We usually use a long piece of chain to drop down into the tank and let it bang around on the sides and bottom.. (one person on one end, another person on the other end..pick it up and rotate from side to side etc) you'll be suprised at what comes out of the tank.
That's why I asked earlier in the thread how long the truck sat before you got it. Old gas breaks down, the inside of the tank can rust and just over time trash collects inside the tank. Then you start driving it again and the crud finds its way to your new carb, fuel lines, fuel pump, filters, and starves the truck for fuel.
Just my opinion until you clean out the tank, or just go ahead and move it under the bed and get it out of the cab if that's the case.. this will happen to you again. 69 Camaro gas tanks work very well in our trucks you just need a flip down tag bracket.
New tank, new lines, new filter would be my approach. Just my .02
Chad
Old 12-15-2015, 05:05 PM   #24
70c10guy
The truck didn't sit before this! When I removed the intake I took the intake and carb off together and I dosconnected my fuel line right before the filter. All the crud from the filter was fed into the bowls because I had the filter higher then the carb when I was taking it off the truck!
Old 12-15-2015, 05:37 PM   #25
CC69Rat
CC69Rat's Avatar
Rgr that.
Chad
