12-14-2015, 12:49 AM | #1 |
Gadgets by carburetor
What is this? Nothing was plugged into it.
12-14-2015, 01:11 AM | #2 |
Re: Gadgets by carburetor
12-14-2015, 10:00 AM | #3 |
TVS
Transmission Vacuum Switch. Used to supply vacuum to the vac pot on the distributor only in high gear. A ground switch on the tranny made it work. |
12-14-2015, 10:10 AM | #4 |
Here is another one behind the carb. It's not "plugged" up either.
12-14-2015, 10:25 AM | #5 |
Two guesses!!
Turbo 400 kickdown switch. Or a high idle solenoid for a/c. Your truck have either a/c or a turbo 400? |
12-14-2015, 10:29 AM | #6 |
12-14-2015, 10:41 AM | #7 |
12-14-2015, 04:45 PM | #8 |
On the linkage, that's a dash pot. It's adjusted so when activated it stops the carb from going down all the way to idle. It works for just a second or two when you completely let off the gas, helps to keep it from stalling. Hope that makes sense. You can probably google dash pot or dashpot to get a better explanation.
____________________________________________ My build thread: Project Moonshiner Bagged & Z Frame 63 http://67-72chevytrucks.com/vboard/s...d.php?t=659205 "I love the smell of grinding metal" |
12-14-2015, 05:13 PM | #9 | |
