Fabricate till you "puke"
Loosing the leafs...
The leafs are coming off the longhorn, in favor of a 2 link/ bag setup. I am not looking to lay the rockers, but want the adjustability , to alter ride height a little, & be able to set preload when I am "playing". At present, I am looking at 2600lb Firestone bags , & plan to mount them on the bars just behind the rear diff. I will run (for now) 2 air lines to be aired up before i leave the shop. I do also plan to bag the front, & add the compressor later, But for now I am trying to deal with traction/hop issues. I am new to the air bag stuff, so i am looking for any info,sites, FAQ's to help with parts selection (single port, dual port, fitting sizes ,ect). Help! crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Mike
NSANE68 has a web site and has allways answered questions. http://www.phatcustoms.com/
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
thanks for the link Smokekiki
