Accuair Installed Not Working????
Installed the air bag setup in my c10. When I turn the key. The compressors go on. Air fills the tanks. The relays show power. The 3/8 hoses are connected to the accuair. The guy at the performance shop said I should see it level off. It doesn't inflate the bags at all. I hit the switches on the control panel and nothing. I went over the diagram and it seems that I hooked it up right. Not much there.
Squarebody guy
Re: Accuair Installed Not Working????
I would probably contact Accuair.
Does your control panel light up? If not then you probably don't have both constant 12v and 12v switched from the ignition to the ECU but then again i wouldn't think the compressors would come on if you use the Accuair brain and pressure sensor. Do you have the Accuair pressure switch or are your compressors wired up with their own relays and pressure sensor.
1988 Chevy R30 Dually Crew-Cab - Build thread Cummins swap + Bagged and Bodied on Semi wheels, work in progress |
