Old 12-14-2015, 10:58 AM   #1
jturner18
Wires beside heater under hood.
What are these? They have been cut.
jturner18 is offline   Reply With Quote
Old 12-14-2015, 01:32 PM   #2
PGSigns
PGSigns's Avatar
Re: Wires beside heater under hood.
Do they go to a three prong plug? If so that was the engine harness.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 12-14-2015, 04:24 PM   #3
ray_mcavoy
Yes, that looks like what's left of the engine harness.
Should be a 6-prong plug with 1 or 2 spots left unused (depending on whether or not the truck was wired for factory gauges or warning lights).
ray_mcavoy is offline   Reply With Quote
Old 12-14-2015, 09:50 PM   #4
65chevysub
65chevysub's Avatar
Definately an engine harness. I had a problem with mine in the 90's while camping. Dang thing came loose and my truck wouldnt start. I now have it glued on with w/strip adhesive. Problem solved.
65chevysub is offline   Reply With Quote
Old 12-15-2015, 01:20 AM   #5
Captainfab
60-66 Nut
Those wires go to the starter and the coil also. With the I6 the water temp wire might be there as well.....don't quite remember for sure.
Old 12-15-2015, 01:52 AM   #6
jtrichard
OIL PRESS /TEMP/START/and ING.-RESISTOR wire to R terminal on solenoid
jtrichard is offline   Reply With Quote
Old 12-16-2015, 02:43 PM   #7
ray_mcavoy
The factory 60-66 Chevy engine wiring harness has:
* A multi colored cloth covered resistance wire going to the starter solenoid R terminal. And then a green or yellow (depending on the year) wire running from the R terminal up to the + coil terminal.
* A dark green wire for the "HOT" light (warning light cluster) or for the temp gauge sending unit (gauge cluster).
* A light green wire for the "COLD" light (warning light cluster) or a black wire going to the large "BAT" stud on the starter solenoid for one leg of the ammeter circuit (gauge cluster).
* A purple wire going to the starter solenoid S terminal.
* A dark blue wire for the "OIL" light (warning light cluster).
The wire colors and connections are the same for either L6 or V8 engines. But the wire lengths and routing are different.
