Old 12-14-2015, 01:53 PM   #1
kenny4454
Power Steering pressue hose for serpentine belt setup
I am having trouble finding a power steering pressure hose that works with a early 90s serpentine setup and a 71 gearbox. There isn't a lot of clearance behind the pump and the engine. Wondering what other guys are using on their setups. If anyone has a Napa part number that would be very helpful. Thanks
kenny4454 is offline   Reply With Quote
Old 12-14-2015, 02:25 PM   #2
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: Power Steering pressue hose for serpentine belt setup
I picked up a 70911 from advance auto for a 75 chevy c10 and it fit perfect, just use the hose fitting bolt out of your old pump in the new one.
http://67-72chevytrucks.com/vboard/s...d.php?t=468729
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 12-14-2015, 03:56 PM   #3
kenny4454
Do you have a serpentine belt setup on your engine? I need a quick 90 degree bend in the line that goes into the back of the power steering pump.
Old 12-14-2015, 04:12 PM   #4
Big Kev-O
Big Kev-O's Avatar
I used a 73 C10 hose from Napa. The bend is more than 90* but it works. I have the 95 serp set up that has the alternator an driver side with the power steering pump below it. The hose has a flare type connection to the power steering pump.
Made in America by Americans
Big Kev-O is offline   Reply With Quote
Old 12-14-2015, 04:39 PM   #5
71meangreenc10
I sure do,
That is my write up I sent.
Smitty
71 C30 Wrecker
Old 12-14-2015, 09:49 PM   #6
kenny4454
Thanks, I just had my local advance order a PS hose for both a 73 and 75 C10 to see which one works better. They didn't show part number 70911, so I just went off make and model that you suggested. I'll let you know once the hose comes in if it works.
Old 12-15-2015, 05:08 PM   #7
71meangreenc10
EDELMANN 70911 {#7814277, 7819065, 7828164} 3/8" Male Inverted Flare x 7/16" Male Inverted Flare x 31-1/2"
Category: Power Steering Pressure Hose
These are the crossover numbers from Rock Auto, if the hose doesn't come in right.
Smitty
71 C30 Wrecker
Old 12-15-2015, 05:32 PM   #8
kenny4454
Awesome. Thanks!
