Old 12-14-2015, 04:22 PM   #1
estebansocarras
fuel guage issue
hi guys i have a question ,just bought a 69 stepside & had an aftermarket underdash fuel guage installed ,i just ordered the original from lmc , iam going to use the same wiring on the after market unit which has the 2 (p)&(n) wires plus the sendin units wire ,now i just want to connect the wires directly to the unit not to the circuit board which doesnt look good & i dont want to connect the wires wrong & mess up the gauge i tried loading a picture but iam not to pc friendly yet ,,please help thanks
estebansocarras is offline   Reply With Quote
Old 12-14-2015, 04:31 PM   #2
estebansocarras
Re: fuel guage issue
[/IMG]
Old 12-14-2015, 04:35 PM   #3
estebansocarras
Old 12-14-2015, 06:43 PM   #4
kehstr
kehstr's Avatar
do you plan on plugging it into the connector that goes into the printed circuit, or straight up to the fuel gauge
kehstr is offline   Reply With Quote
Old 12-14-2015, 06:47 PM   #5
kehstr
kehstr's Avatar
if you want to use the printed circuit, use this picture
Name:  cluster connector with gauges.jpg
Old 12-15-2015, 06:18 PM   #6
estebansocarras
yea i just want to connect strait up to rear of fuel gauge ,cause the tabs that are for the fuel on the curcuit are all gone ,they were distroyed ,the only ones cause the rest i cleanup good & are working ,,,thanks
Old 12-15-2015, 06:22 PM   #7
estebansocarras
i think positive wire goes to post A on my diagram ,negative wire on B ,& the sending wire unit on C , i just want to get them strait or else ill end up burning the guage which is new ,,,thanks
Old 12-15-2015, 09:41 PM   #8
VetteVet
Msgt USAF Ret
VetteVet's Avatar
You can check this link and I think you will find that the connections are as follows.
A. Is the sending unit
B. Is positive.
C. Is the gauge ground.
http://67-72chevytrucks.com/vboard/s...d.php?t=640615
Here's a cluster diagram showing the wiring.
It doesn't show the ground but it's there.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 12-18-2015, 03:56 PM   #9
estebansocarras
thanks vettevet & kehstr gotit going this morning ,both diagrams were handy ,i even printed them out ,,thanks again & Happy Holidays
Old 01-14-2016, 05:03 PM   #10
kehstr
kehstr's Avatar
Just out of curiosity, which connector is which on the back of the fuel gauge.
