Old 12-14-2015, 04:36 PM   #1
hdff
hdff's Avatar
AC Wire ID help please
Found this wire when I pulled the AC and heater. Can someone tell me is this just a ground wire? it runs from out on the firewall to inside on the side of the heated to a relay. the wire is gone and I don't know if the rats at some point in time ate the plastic off or what but I need to replace it. also as I was pulling off the heater box this spring fell down from somewhere, any ideas?
thanks
Keith
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach
"Wanda"
Don't argue with idiots, People watching may not be able to tell the difference...
There's someone in my head........But it's not me......
cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394
hdff is offline   Reply With Quote
Old 12-15-2015, 12:47 AM   #2
snipescastle2
snipescastle2's Avatar
Talking Re: AC Wire ID help please
Well, that does look like a ground wire, as the wiring to the relay is a molded connector.can't say where the spring came from, never seen one like that.
HTH,
Ben
snipescastle2 is offline   Reply With Quote
Old 12-15-2015, 12:59 AM   #3
hdff
hdff's Avatar
The wire is in bad shape. It appears to only go from the fire wall to one of the screws that holds the relay on
"Wanda"
Old 12-15-2015, 03:23 AM   #4
F.A.A.benny
The spring belongs to the button switch on the diverter duct that connects to the heater box. I'm guessing the button switch was pulled apart.
F.A.A.benny is offline   Reply With Quote
Old 12-15-2015, 03:28 AM   #5
F.A.A.benny
The button switch is seen here on the duct.
Old 12-15-2015, 03:32 AM   #6
hdff
hdff's Avatar
Yes the button switch was apart and was getting replaced. Thanks Benny as you can see I finally pulled it. Once I finish getting the compressor and brackets bolted up I'll be giving you a call, probably later this week. Where do you get the boxes you ship the evaporate/fan assembly in?
"Wanda"
Old 12-15-2015, 03:34 AM   #7
hdff
hdff's Avatar
Is that duct for sale?
"Wanda"
Old 12-15-2015, 03:34 AM   #8
F.A.A.benny
No problem, looking forward to hearing from you.
Old 12-15-2015, 03:38 AM   #9
F.A.A.benny
I sold that duct last year. Just remembered I had a picture of it. If you need one I believe I have one or two good ones. Those things usually have the door broken more often than not when I find them.
Old 12-15-2015, 03:42 AM   #10
hdff
hdff's Avatar
We'll talk about it when I call
"Wanda"
Old 12-15-2015, 07:47 AM   #11
Tdrcreyn4
Tdrcreyn4's Avatar
The wire is a ground for the high speed blower relay that you have pictured. Because the box it attaches to is fiberglass they ran it out and grounded it elsewhere.
1968 C10 292/3 spd - sold
1969 K10 350/3 spd/205 - sold
1971 K5 350/4 spd/ 205 - sold
1970 K20 350/350/205 - sold
1969 K20 396/400/205 - work in process
Tdrcreyn4 is offline   Reply With Quote
Old 12-15-2015, 09:16 AM   #12
snipescastle2
yeah, that's the compressor switch on the diverter box.....
