Old 12-14-2015, 04:38 PM   #1
64chevtruck
C30 Crossmember question
Hi guys, do people pancake the CMs on duallys like is done to half tons>? I have looked for 2 hours and found no info on it,
How bout Z frames on duallys>?
Please direct me to any threads you know of with this info,
Thanks in advance
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438
70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983
76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612
79 GMC 3500 Fleetside LB 454/400
90 Suburban Silverado 4x4 350/700R4
97 1500 Cheyenne Short Fleet 350/5sp
64chevtruck is offline   Reply With Quote
Old 12-14-2015, 04:56 PM   #2
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
Re: C30 Crossmember question
I should know this as I have a c30 but check to see if your crossmember sits below the lowest portion of the frame. If not that is why you don't see anyone pancake the member as its not needed to lay frame.
If you wanted to lay body there is another whole set of mods you would need to do, chopping the bottom of the frame off and a Z is one way and chopping the top of the frame off and moving the body mounts is another.
There is another great resource specific to duallys and C30s at duallyscene.
Also DblTrbl has a good thread going HERE that has some great info.
1988 Chevy R30 Dually Crew-Cab - Build thread Cummins swap + Bagged and Bodied on Semi wheels, work in progress
Ghostwhite is offline   Reply With Quote
Old 12-14-2015, 05:32 PM   #3
slotard
I've certainly seen some builds here that were duallys with SFBD.
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 12-14-2015, 05:38 PM   #4
64chevtruck
Thank you Ghost, Im going through that thread right now,
Thanks Slot, Ill search SFBD now :}
Old 12-14-2015, 06:16 PM   #5
slotard
It took me a while to figure out what it meant, once I figured out it made sense (pretty sure it's SubFrame Body Drop).
1973 C20, 350/350
Old 12-14-2015, 06:19 PM   #6
tinydb84
tinydb84's Avatar
SFDB = Stock floor body drop.
You would section some of the frame height out to lower the cab while keeping the floor stock.
I don't know about C30's but C20's crossmember/arms are the lowest part.
David
Instagram: myfabguy
Old 12-14-2015, 06:39 PM   #7
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
If you tell us your intentions we will be better able to make some suggestions.
Old 12-14-2015, 06:47 PM   #8
64chevtruck
Oh no problem, Lower it to the ground ACAP. (as cheap as possible) Leave it unfinished and drive the wheels off it. It will be used like a car for the rest of its life with me.
The lower the better.
Old 12-14-2015, 07:06 PM   #9
bbbc10
Diggin The SquareLife
I see one problem cheap as possible
bbbc10 is offline   Reply With Quote
Old 12-14-2015, 07:11 PM   #10
64chevtruck
I hear ya. I just meant I'l be doing all my own cutting, grinding, and welding. Not opening a big box of shiny porter built stuff.....
Old 12-14-2015, 07:24 PM   #11
SCOTI
SCOTI's Avatar
I sectioned mine 1.5".
With the frame rails on the ground, my front lower a-arms are about 1.5" off the ground. With my frame @ ride height (factory rails @ 5"), that extra 1.5" means better clearance.
If you're 'Z-ing' the frame, it's not worth messing w/the crossmember.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 12-15-2015, 11:22 PM   #12
DblTrbl
DblTrbl's Avatar
For what it's worth...I've got roughly $500 in steel so far for my SFBD and I'm nearing completion of the heavy fab work. The cost involved isn't too bad considering the end result, but it's a TON of work.
83 Crew Dually build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=686192
Instagram: lofab77
DblTrbl is offline   Reply With Quote
Old 12-16-2015, 02:45 PM   #13
tinydb84
tinydb84's Avatar
I initially sectioned a spare crossmember but ended up wanting to go lower. Much easier to do the crossmember than a Z btw.
^^^this. I stop by the steel shop when I am free and grab all the 3/16'' I can find in the remnants. I think I have $40 in my SFBD and the same in my rear notch. I don't even know if I have that much in my Z. I ended up spending $300 in my steering linkage though.
But damn it is a lot of work!
David
Instagram: myfabguy
Old 12-16-2015, 03:51 PM   #14
SCOTI
SCOTI's Avatar
I agree w/this statement. But when you do the work & it's not enough (thus requiring a Z or something else as well), seems it would be easier to just do the Z by itself to begin with.
I like sectioning the x-member because it does not change the position of the motor/drivetrain like the Z will. Helps minimize that domino effect. While it's not 3", the 1.5" difference still can help (especially w/ground clearance @ similar ride heights vs not doing it).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-16-2015, 09:50 PM   #15
64chevtruck
Hi, Ive had tranny and exhaust dragging on the ground on past builds so I dont mind the idea of moving the motor and stuff up with a Z,
But last night as I was scraping my CM getting ready to section it I was going through spare parts,,,,
In the pile I found a sectioned half ton CM, some half ton drop spindles, some LCAs that are already cupped, a later front end with disks, some bags, plates and more.
Im going to bolt in my half ton sectioned crossmember and switch the whole front end to half ton,
Ill get rid of the dually front rims and other problems, (Dually drop spindles were 400 dollars too!)
Ive already mocked this up and it looks like it will work,
Like I said before, This truck is not going to be used like a truck anymore anyway, so half ton front end seems fine,
I plan on doing whatever it takes to get this truck on the ground, it is the longest one, it should also be the lowest one I think,
PS Just to clarify...I wish I WAS opening a box of shiny PB stuff
Old 12-16-2015, 10:10 PM   #16
SCOTI
SCOTI's Avatar
What about the rear?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-17-2015, 01:11 AM   #17
64chevtruck
Ill probably do the same stuff I did to my 70 GMC, Raise the spring perches up, stretch the shackles, raise the tubs and stuff.
Old 12-17-2015, 03:04 AM   #18
SCOTI
SCOTI's Avatar
1/2 ton or what rear end? It's not a dually anymore unless there's the HD suspension.... Sounds like a CC 1/2 ton w/the stated changes.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-17-2015, 03:06 AM   #19
SCOTI
SCOTI's Avatar
1/2 ton? It's not a dually anymore.... It sounds like a CC 1/2 ton w/the stated changes.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-17-2015, 03:39 AM   #20
64chevtruck
Ill leave the dual wheels on it. I like the way they look.
Old 12-17-2015, 10:11 AM   #21
DblTrbl
DblTrbl's Avatar
I'd be afraid that you're going to run into some big problems. Not that it can't be done, but there are some significant differences between the c10 frame and the c30 frame, not the least of which is the frame height where the crossmember bolts on. Even Porterbuilt has stated that "the c30 crossmember is an animal all to its own". Nate doesn't sell the c10 drop members to be installed on c30's.
All of that being said, sectioned member or not, you'll still be 3.5" up without a SFBD...and by the time you go through all of that trouble, why not just Z the frame while you have the welder out and truck disassembled...
Instagram: lofab77
Old 12-17-2015, 10:12 AM   #22
SCOTI
SCOTI's Avatar
I strongly urge you to take a step back & re-think your plan. 1/2 ton front components w/5-lug wheels & a 1-ton set-up w/8-lug wheels out back is going to be a head scratcher.
Why not sell the 1/2 ton stuff you have for the front to offset the cost of the 1-ton dually spindles?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-17-2015, 10:24 AM   #23
SCOTI
SCOTI's Avatar
The 1/2 ton x-member will bolt right in where the 1-ton unit was. When swapping in a sectioned x-member, the 6x original holes on the horizontal surface (3x each side) remain un-touched. The 8x holes on the vertical surface of the frame (4x each side) require re-drilling for both 1/2 ton & 1-ton.
The upper a-arm mounting studs are 1.2" for the 1/2 ton vs 9/15" for the 1-ton. But they can be swapped out or a 1/2 ton upper arm can be utilized w/a 1-ton BJ swap (only recommended if the truck is going to be used for light duty).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-17-2015, 07:39 PM   #24
64chevtruck
[QUOTE=SCOTI;7413515]I strongly urge you to take a step back & re-think your plan. 1/2 ton front components w/5-lug wheels & a 1-ton set-up w/8-lug wheels out back is going to be a head scratcher.
Why not sell the 1/2 ton stuff you have for the front to offset the cost of the 1-ton dually spindles?[/QUOTE
Yes the stuff will bolt up, But then Ill run in brake proportion problems, and it will be a fair bit of work to make the truck weaker......Cant do it.
Im headed back out to finish cleanup and proceed with sectioning the stock CM,
Thank a bunch to Scotti and DT for kicking this around with me.
PS anyone know where to get dually drop spindles for less than 400?
Have a good weekend.
Andy
Old 12-17-2015, 08:08 PM   #25
DblTrbl
DblTrbl's Avatar
Andy
Suspension Source (StreetEdge) that's where I found mine. Seem to be as good if not better quality than the Belltechs I've had in the past.
Instagram: lofab77
