12-14-2015, 06:54 PM | #1 |
Center Link/Drag Link
Does any vendors sell a new Center Link/Drag Link for a 1965 C10? Is it only a junkyard part?
'65 Tiki Sea 10: http://67-72chevytrucks.com/vboard/s...d.php?t=682356 |
12-14-2015, 07:06 PM | #2 |
Re: Center Link/Drag Link
They make em. Lots of folks carry them.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
12-14-2015, 08:35 PM | #3 |
12-14-2015, 09:11 PM | #4 |
I did a google search and they show up but when I went to them they had everything but. I think I have one if needed.
Jimmy
12-14-2015, 09:21 PM | #5 |
67-72 parts collector,…
I didn't think the stock centerlinks were produced by anyone.
Hotchkis makes an aftermarket version but it's pricey,...
12-14-2015, 09:53 PM | #6 |
I don't think you can get an after market one .You can try Rare Parts they too are a bit pricey
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
12-14-2015, 10:24 PM | #7 |
Well...that's not the replies I was hoping to read... I have the power assist center link but was wondering if the non-assist was different (less holes). Also, haven't even seen any 'pricey' after-market alternatives.
And...if anyone might know of the 'range' that the center links were designed similar, in case of a junkyard find, would be helpful, Thanks again
12-15-2015, 01:26 AM | #8 |
60-66 Nut
The factory power assist draglink is completely different from a manual steering draglink. There are 2 different ones for the '63-'70 trucks, but I don't remember exactly what year they changed. I believe the main difference is the size of the tapered hole for the inner tierods.
12-15-2015, 02:18 AM | #9 |
Thanks... So, if I wanted to do away with the power assist ram on the center link and simply use a power steering box with a 14:1 ratio, I would need to source the manual center link of an applicable year?
12-15-2015, 07:18 AM | #10 |
When I did the power conversion on both my trucks I used the 73 to 87 box with John's plate. I also swapped everything from the donor truck from side to side. I used the drop spindles with the 73 and up tapers. If keeping the early spindles then tie rod adapter sleeves are needed. Lots of information in the FAQ section under the power steer conversion section.
Jimmy
12-15-2015, 11:54 AM | #11 |
The pitman arm is also different.
