Full time to part time 4x4 do I need hubs?
I've got a 1975 blazer with an np203 transfer case. About a year ago the front drive shaft broke and was removed. So far I have not replaced it. I did just have a part time kit installed in the transfer case. In order to install a new front drive shaft and have 4x4 operate correctly will I need to replace the full time hubs with manual locking hub?
Thanks. |
Moderator
![]() Join Date: Oct 2008
Re: Full time to part time 4x4 do I need hubs?
You can run part or full time 4wd with the full time 4wd slugs in the hubs. It's the same as driving with hub locks in the lock position.
If you want to disconnect the axle from the wheels install manual hub locks.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
There are some advantages of manual - with them unlocked the axles and driveshaft won't spin, reducing friction and any vibrations - but they aren't mandatory.
1973 C20, 350/350 |
![]() Join Date: Oct 2009
it's worth it. factory spicer hubs are pricey, but Warn Premium locking hubs aren't too bad and they're plenty tough. About $150-270 new, depending on which ones you buy.
https://www.google.com/search?q=summ...+hubs&tbm=shop |
If your putting in a part time kit its silly NOT to put in manual hubs. The point of the part time kit is to take stress and wear off the front components. You can only complete this with a part time kit.
| Bookmarks |
