Old 12-14-2015, 08:57 PM   #1
v1500
Question ???fuel pump issues???
I replaced my fuel pump oh(1987gmcv1500,350tbi) 2 years ago very shortly after I tore the motor up it sat for 2 years I finally replaced the motor put a new batt. In turned on the switch and no fuel pump hum so I bypassed the relay and put in a toggle I drove the truck about 100 miles from home and it started running bad it blew an inline fuse I had a computer put on it it came back as a bad map sensor replaced it no help replaced coolant temp sensor throttle poss sensor then found a vac leak fixed it and it done fine for a few miles then ran bad again barley made it home could the fuel pump go bad just sitting?????
v1500 is offline   Reply With Quote
