Old 12-15-2015, 02:53 AM   #1
WOLFMANmike
WOLFMANmike's Avatar
65 c10 longbed fleetside tires
1965 fleetside long bed can i fit 275.60.15s in the rear ? without massaging the sheet metal or cutting tubs ? better yet with stock suspension and lowering springs what is the widest tire i can tuck under it for the hot rod look with no rubbing thanks guys pics of them tucked under would be great too if you can Happy Truckin
WOLFMANmike is offline   Reply With Quote
Old 12-15-2015, 07:10 AM   #2
PGSigns
PGSigns's Avatar
Re: 65 c10 longbed fleetside tires
I have the same tire under mine. I got some room on the inside to get maybe an inch more tire. Would need more back spacing to do it and then search the section width to pick a tire. The wheel and tire combo of width, tire size and tire section measurement will give you the answer on the max.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 12-15-2015, 07:38 AM   #3
WOLFMANmike
Jimmy
Can I see a pic of your 275.60.15s tucked ?
Old 12-15-2015, 10:46 PM   #4
racecougar
racecougar's Avatar
They were only on there to roll the truck around, but those are 275/60R15's on 15x8.5" wheels with 3" backspace.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 12-18-2015, 12:15 PM   #5
64fleetsteve
Heres my 64 with 275.60.15 on the rear. when aired out I have an inch or a little less on both sides of the tire.
64fleetsteve is offline   Reply With Quote
Old 12-18-2015, 01:24 PM   #6
ol_skool_chevy
ol_skool_chevy's Avatar
I have 285x70x15 in the rear they fit but I would not recommend them. they are extreamly hard to find, very expensive and hard to change if you have a flat..
I have heard the 275x60x15 is better
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 12-18-2015, 06:23 PM   #7
WOLFMANmike
ok thanks guys i like the look of them on 64fleetsteve looks aggressive which is what i want ... right now it has 31s in the rear but i think the 275.60.15 will look just right ... i know its gonna raise my RPMs but i dont think it will be to bad ... the 275.60.15s i can get for $80.00 a pop Cooper Cobras i cant afford the BFGs lol thanks again all of you for the help
