Old 09-18-2003, 12:02 AM   #1
DANL
How To Grease Upper 4x4 Ball Joint
Hey, can you 4x4 experts tell me how to grease the upper ball joints on a K5? I have new joints, but the uppers do not have grease fittings. The mechanic said there is not enough clearance between ball joint and u-joint for grease fitting.
Thanks in advance.
...Dan
DANL is offline   Reply With Quote
Old 09-18-2003, 08:36 AM   #2
smokekiki
Mike
smokekiki's Avatar
If it has a plug in it,you can thread a grease fitting in to grease it then put the plug back in.Or you can get a neddle adapter for your grease gun.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 09-18-2003, 10:27 AM   #3
palallin
Thank Chevy and Dana for the earlier, Closed-knuckle axles . . .
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 09-18-2003, 10:05 PM   #4
DANL
Hey smokekiki, thanks for the reply. I will try the first recommendation. Also is needle used to penetrate joint boot?
Thanks again.
...Dan
Old 09-19-2003, 01:24 AM   #5
Duallie
Duallie's Avatar
DON'T PUT A HOLE IN THE BOOT! The proper way to grease a "greasable" upper ball joint on a 4X4 is to yank the hub and spindle and pull the halfshafts out! Then pry out the zerk cap and thread in an angled zerk. After greasing, reinstall the cap and reassemble. Whoever replaced the ball joints should've greased them, too.
Don't try to leave a zerk in there; the first quarter turn of the driveshaft will bust it off.
Just as if I knew what I was doin'
Duallie is offline   Reply With Quote
Old 09-19-2003, 09:38 PM   #6
smokekiki
Mike
smokekiki's Avatar
No a needle is not for going thru the boot.It may fit in the hole for the grease zerk.
Old 09-19-2003, 11:01 PM   #7
DANL
Hey Duallie, thanks for the info.
...Dan
